Remote execution seems to be having an issue. If I run a command everything goes great, but if the command fails on any systems or I try to rerun I’ll click the submit button and nothing happens. I’d be happy to attach any logs you like, just not sure which ones will be helpful for this. So it’s only when rerunning commands or rerunning on failed that the issue happens.
