I have some vmware/vsphere (ESX5) related issues when creating or deleting
a host with foreman 1.2 RC1.
I expected the fog version that foreman 1.2 uses would be at least 1.10 or
1.11.1 but for some reason 1.8.0-3 is installed from RC1 yum repo. Older
then the version in foreman 1.1, why?
My mistake, I didn't realise it was out of date. 1.11.1 has been built
since and will be in RC2, hopefully that'll fix your issues!
> deleting a host with foreman 1.2 RC1.
> or 1.11.1 but for some reason 1.8.0-3 is installed from RC1 yum repo.
> Older then the version in foreman 1.1, why?
Dominic Cleal
Red Hat Engineering
Here's the build if you want to try updating in the meantime:
http://koji.katello.org/packages/ruby193-rubygem-fog/1.11.1/3.el6/noarch/ruby193-rubygem-fog-1.11.1-3.el6.noarch.rpm
Dominic Cleal
Red Hat Engineering
Installed fog-1.11.1 and the following dependencies
ruby193-rubygem-excon-0.20.1-1.el6.noarch.rpm
ruby193-rubygem-excon-doc-0.20.1-1.el6.noarch.rpm
ruby193-rubygem-metaclass-0.0.1-9.el6.noarch.rpm
ruby193-rubygem-metaclass-doc-0.0.1-9.el6.noarch.rpm
ruby193-rubygem-mocha-0.12.1-2.el6.noarch.rpm
ruby193-rubygem-mocha-doc-0.12.1-2.el6.noarch.rpm
ruby193-rubygem-net-scp-1.1.0-2.el6.noarch.rpm
ruby193-rubygem-net-scp-doc-1.1.0-2.el6.noarch.rpm
ruby193-rubygem-net-ssh-2.6.7-1.el6.noarch.rpm
ruby193-rubygem-net-ssh-doc-2.6.7-1.el6.noarch.rpm
But still doenst work
I'm getting the following errors in the log and the screen with vmdetails
links network, cpus and disk is emty.
Started GET "/hosts/user.jpg" for 192.168.88.1 at 2013-06-04 09:47:14 -0700
Processing by HostsController#show as HTML
Parameters: {"id"=>"user.jpg"}
Rendered common/404.html.erb within layouts/application (0.7ms)
Rendered home/_user_dropdown.html.erb (1.2ms)
Read fragment views/tabs_and_title_records-1 (0.2ms)
Rendered home/_topbar.html.erb (1.3ms)
Filter chain halted as :find_by_name rendered or redirected
Completed 404 Not Found in 12ms (Views: 6.1ms | ActiveRecord: 0.9ms)
Started POST "/hosts/compute_resource_selected" for 192.168.88.1 at
2013-06-04 09:47:18 -0700
Processing by HostsController#compute_resource_selected as /
Parameters: {"architecture_id"=>"", "compute_resource_id"=>"1",
"operatingsystem_id"=>""}
Rendered compute_resources_vms/form/_vmware.html.erb (162.0ms)
Rendered hosts/_compute.html.erb (201.9ms)
Operation FAILED: undefined method `init' for #<Class:0x000000081328d0>
Rendered common/500.html.erb (11.0ms)
Completed 500 Internal Server Error in 226ms (Views: 13.3ms | ActiveRecord:
0.0ms)
Op woensdag 29 mei 2013 00:36:59 UTC+2 schreef Dominic Cleal het volgende:
Dominic Cleal
Red Hat Engineering
>> 1.10
>> Dominic Cleal
>> Red Hat Engineering
> ActiveRecord: 0.0ms)
> Created the debug logging if needed or interrested.
Op dinsdag 4 juni 2013 18:54:13 UTC+2 schreef Ronaldo M het volgende:
Could you create a bug on redmine please and attach the debug with the
full stack trace?
http://projects.theforeman.org/projects/foreman/issues/new
Thanks!
> Op woensdag 29 mei 2013 00:36:59 UTC+2 schreef Dominic Cleal het > volgende:
> creating or
> least 1.10
> yum repo.
> been built
> Dominic Cleal
> Red Hat Engineering
> But still doenst work :(
> vmdetails links network, cpus and disk is emty.
> 09:47:14 -0700
> Processing by HostsController#compute_resource_selected as */*
Dominic Cleal
Red Hat Engineering
