Hi folks,
I upgraded our Foreman instance to 1.20 (katello 3.9) on Friday and assumed all was ok as i never encountered any issues along the way and the gui looked fine post upgrade too.
Anyway I’ve since noticed that none of the daily syncs have completed and I’m seeing this error when i browse any of my defined products - wrong number of arguments (given 0, expected 1).
I kicked off a manual sync but none of the tasks ever completed, they all sat at 0%.
I decided to refresh the manifest based on some posts I’ve read, that task got to 16% and didn’t go any further.
I’m running CentOS 7.6 patched to the latest level.
This is what I can see in the production log in regards to the wrong number of arguments error.
2019-06-03T09:40:46 [E|app|96288] ActionView::Template::Error: wrong number of arguments (given 0, expected 1)
/opt/rh/rh-ruby25/root/usr/local/share/gems/gems/foreman_datacenter-1.20.3/app/helpers/foreman_datacenter/application_helper.rb:79:in `object_name'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/core_ext/object/try.rb:19:in `public_send'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/core_ext/object/try.rb:19:in `try!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/core_ext/object/try.rb:8:in `try'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.9.1/app/views/katello/api/v2/layouts/resource.json.erb:1:in `_3bfc97bc82160529dbfb6a6437c6eb13'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/template.rb:159:in `block in render'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/notifications.rb:170:in `instrument'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/template.rb:354:in `instrument_render_template'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/template.rb:157:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/deface-1.3.2/lib/deface/action_view_extensions.rb:41:in `render'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/template_renderer.rb:66:in `render_with_layout'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/template_renderer.rb:52:in `render_template'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/template_renderer.rb:16:in `render'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/renderer.rb:44:in `render_template'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/renderer/renderer.rb:25:in `render'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/rendering.rb:103:in `_render_template'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/streaming.rb:219:in `_render_template'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/rendering.rb:84:in `render_to_body'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/renderers.rb:142:in `render_to_body'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/rendering.rb:25:in `render'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rendering.rb:36:in `render'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:46:in `block (2 levels) in render'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/core_ext/benchmark.rb:14:in `block in ms'
/opt/rh/rh-ruby25/root/usr/share/ruby/benchmark.rb:308:in `realtime'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/core_ext/benchmark.rb:14:in `ms'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:46:in `block in render'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:87:in `cleanup_view_runtime'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/railties/controller_runtime.rb:31:in `cleanup_view_runtime'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:45:in `render'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.9.1/app/lib/katello/api/v2/rendering.rb:44:in `respond_with_template'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.9.1/app/lib/katello/api/v2/rendering.rb:54:in `respond_with_template_resource'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.9.1/app/lib/katello/api/v2/rendering.rb:6:in `respond_for_show'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.9.1/app/controllers/katello/api/v2/products_controller.rb:90:in `show'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:194:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/usr/share/foreman/app/controllers/api/v2/base_controller.rb:163:in `disable_json_root'
/opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.7.1/lib/audited/sweeper.rb:14:in `around'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.9.1/app/controllers/katello/concerns/api/api_controller.rb:39:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:134:in `process'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/rendering.rb:32:in `process'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:191:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:252:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/mapper.rb:48:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:840:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/static_dispatcher.rb:65:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/extractor/recorder.rb:137:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/tempfile_reaper.rb:15:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/etag.rb:25:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/conditional_get.rb:25:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/head.rb:12:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:38:in `call_app'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:28:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.9.1/lib/katello/prevent_json_parsing.rb:12:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/runtime.rb:22:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-6.0.0/lib/secure_headers/middleware.rb:13:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in `block in call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `call'
Active jobs
foreman=# select id, label, started_at, state, result from foreman_tasks_tasks where state != 'stopped';
id | label | started_at | state | result
a0a7be11-93db-4110-a631-c2049ff0b906 | CreatePulpDiskSpaceNotifications | | scheduled | pending
9f60d644-5116-40ab-9b3c-cf4b66383569 | Actions::Katello::Repository::Sync | 2019-06-03 06:34:45 | running | pending
caf484cd-95a9-40a2-b41e-a8c5884a7624 | Actions::Katello::Repository::Sync | 2019-06-03 06:35:03 | running | pending
7a898089-bfcd-4704-aafb-ca9050fc63ff | Actions::Katello::Repository::Sync | 2019-06-03 06:34:53 | running | pending
5a30543c-f383-49a2-974a-b5476c624b20 | Actions::Katello::Repository::Sync | 2019-06-03 06:35:08 | running | pending
5f399c59-ced7-431c-b0bb-ee20223a742e | Actions::Katello::Repository::Sync | 2019-06-03 06:35:09 | running | pending
e3ba6db7-1a02-43dd-bff2-c8b674257d9d | Actions::Katello::Repository::Sync | 2019-06-03 06:35:20 | running | pending
63049575-ce8f-4222-87be-8ec5f7612210 | Actions::Katello::Repository::Sync | 2019-06-03 06:34:31 | running | pending
9be6ff0c-f804-4427-b79b-6f2ca85f71de | Actions::Katello::Repository::Sync | 2019-06-03 06:34:32 | running | pending
3347196c-fae5-4338-ad7e-26077491509b | Actions::Katello::Repository::Sync | 2019-06-03 06:35:13 | running | pending
a8dc4070-5033-4307-ba2e-46b4cc0a3b5b | Actions::Katello::Repository::Sync | 2019-06-03 06:34:25 | running | pending
1c60eefb-b4ea-4ee2-bd34-b8d756c84efe | Actions::Katello::Repository::Sync | 2019-06-03 06:37:19 | running | pending
68fede1d-1253-4681-88cc-3d16d099c2c4 | Actions::Katello::Repository::Sync | 2019-06-03 06:36:17 | running | pending
e17dfbf8-dce2-4b9e-8120-c1cb3a5c72f8 | Actions::Katello::Repository::Sync | 2019-06-03 06:35:59 | running | pending
8c73e4a2-14b8-45dc-9e34-5ab1e8b07a5c | Actions::Katello::Repository::Sync | 2019-06-03 06:36:06 | running | pending
170c3d65-9b50-451f-b748-ef7e4aec976a | Actions::Katello::Repository::Sync | 2019-06-03 06:35:34 | running | pending
69ffadf7-3996-4e7e-8ae8-eb10e6f2d9a1 | Actions::Katello::Repository::Sync | 2019-06-03 06:35:19 | running | pending
eafaa3e1-e56d-4439-9e30-2f5e8f26453f | Actions::Katello::Repository::Sync | 2019-06-03 06:35:38 | running | pending
11e10442-5fa8-4d7f-b2d2-ce8722dc6e7d | Actions::Katello::Repository::Sync | 2019-06-03 06:35:48 | running | pending
84f01317-14d0-4563-b3b5-694e934d9a9f | Actions::Katello::Repository::Sync | 2019-06-03 06:35:25 | running | pending
fbfe69e8-3747-4167-8129-685f409a9c3a | Actions::Katello::Repository::Sync | 2019-06-03 06:37:34 | running | pending
4452497b-db5a-4dad-b9e9-dd08262e65b5 | Actions::Katello::Repository::Sync | 2019-06-03 06:37:11 | running | pending
c6113c0c-8e41-4ba1-a33c-304cc88ff79d | Actions::Katello::Repository::Sync | 2019-06-03 06:36:21 | running | pending
01f62e49-4d86-4bce-b574-e62942e3cd4f | Actions::Katello::Repository::Sync | 2019-06-03 06:36:11 | running | pending
c1fb4c2e-702a-4d32-897d-464167c765ac | Actions::Katello::Repository::Sync | 2019-06-03 06:35:28 | running | pending
23995ea9-93df-4e31-970b-6b23ec11a720 | Actions::Katello::Repository::Sync | 2019-06-03 06:37:02 | running | pending
9c6c1270-3bf2-4136-89ca-1815ccfdc524 | Actions::Katello::Repository::Sync | 2019-06-03 06:36:29 | running | pending
61bc8100-e150-4190-93d2-f60f56c54f8f | Actions::Katello::Repository::Sync | 2019-06-03 06:36:33 | running | pending
a09e38ac-822f-4d24-abf8-05994234cf9f | Actions::Katello::Repository::Sync | 2019-06-03 06:36:55 | running | pending
7d5040a5-6301-44a9-ba21-d07caddb75ca | Actions::Katello::Repository::Sync | 2019-06-03 06:37:08 | running | pending
6875fc47-efc6-477f-b07e-ecffc81ba869 | Actions::Katello::Repository::Sync | 2019-06-03 06:35:36 | running | pending
482f4bf7-4825-40a2-b8a1-6a35a5f5c704 | Actions::Katello::Repository::Sync | 2019-06-03 06:35:31 | running | pending
07bed047-921d-4165-a159-9790b8d2a764 | Actions::Katello::Repository::Sync | 2019-06-03 06:35:41 | running | pending
e861090f-e564-44df-8edc-138ff9a66e56 | Actions::Katello::Repository::Sync | 2019-06-03 06:35:44 | running | pending
d6a7fda8-ec19-4ce9-865d-23b2d407762f | Actions::Katello::Repository::Sync | 2019-06-03 06:35:54 | running | pending
5bd7e5ca-4b78-42b1-8138-0bcc0ebfe00d | Actions::Katello::Repository::Sync | 2019-06-03 06:36:25 | running | pending
2d53a3de-b31d-438b-ade2-7506748cc069 | Actions::Katello::Repository::Sync | 2019-06-03 06:36:39 | running | pending
b3b41e7d-c1d2-4ba9-abbf-31c6656bfb74 | Actions::Katello::Repository::Sync | 2019-06-03 06:36:43 | running | pending
cb9de7e0-e911-4168-8e77-7a001e705664 | Actions::Katello::Repository::Sync | 2019-06-03 06:37:38 | running | pending
4f0d5e3f-25ce-469d-b189-b7f31314693b | Actions::Katello::Repository::Sync | 2019-06-03 06:36:49 | running | pending
c1536e5d-9164-4a0d-b734-37d5fd3e6936 | Actions::Katello::Repository::Sync | 2019-06-03 06:36:58 | running | pending
674a518d-548a-4c46-9ade-db843f1e47e7 | Actions::Katello::Repository::Sync | 2019-06-03 06:37:16 | running | pending
8390be98-2c64-4b90-b7a7-2947dce7daf2 | Actions::Katello::Repository::Sync | 2019-06-03 06:37:28 | running | pending
a1bdaceb-2cbf-4d24-95b3-09bc329f7c0d | Actions::Katello::Repository::Sync | 2019-06-03 06:35:50 | running | pending
e8d29dc5-63a9-481e-9273-2b7535c6f2f1 | Actions::Candlepin::ListenOnCandlepinEvents | 2019-05-31 14:09:43 | running | pending
df6a92da-f038-47e2-a558-828900f973bf | Actions::Katello::EventQueue::Monitor | 2019-05-31 14:09:44 | running | pending
3815d45e-712b-4701-84b8-9daa6b15834e | Actions::Katello::Repository::Sync | 2019-06-03 06:34:59 | running | pending
c9055874-cce1-492b-b037-59f0fdf50070 | Actions::Katello::Repository::Sync | 2019-06-03 06:34:47 | running | pending
0a5ca21e-3fb3-4faf-a042-e0956138d323 | Actions::Katello::Repository::Sync | 2019-06-03 06:35:57 | running | pending
aa4ebc48-bc69-43a0-8c85-b9dc1b79b422 | Actions::Katello::Repository::Sync | 2019-06-03 06:36:03 | running | pending
9d7906ab-565e-4782-be23-bf83cbe57219 | Actions::Katello::Organization::ManifestRefresh | 2019-06-03 06:56:42 | running | warning
(51 rows)
