I’m running Foreman, ISC DHCPD and Smart Proxy on one libvirt host and cannot get the Proxy to invoke nsupdate to update a remote BIND server. There are no log entries of nsupdate attempts from the Proxy.
BIND nsupdate to be issued by the proxy to remote server.
1.21.2 with proxy functions TFTP, Puppet, Puppet CA, Logs, Dynflow, SSH, DNS, and DHCP
foreman-tasks 0.14.5
foreman_ansible 2.3.3
foreman_cockpit 2.0.3
foreman_default_hostgroup 5.0.0
foreman_dhcp_browser 0.0.8
foreman_remote_execution 1.7.0
foreman_setup 6.0.0
Foreman was installed via Debian Repositories and configured using foreman-installer.
Version: Foreman 1.21.2
Host Environment: KVM/libvirt
Host OS: Debian 9.8
Turning on DEBUG level logging on the the proxy, I do not get any further log entries concerning nsupdate invocation, but the initialization log entries lead me to believe the configuration should allow for nsupdate invocation.
As the foreman-proxy user, I can succesfully manually run nsupdate with the key configured in dns_nsupdate.yml.
grep dns /var/log/foreman-proxy/proxy.log
2019-04-27T07:22:21 [D] 'dns' settings: 'dns_ttl': 86400 (default), 'enabled': https, 'use_provider': dns_nsupdate (default)
2019-04-27T07:22:21 [D] 'dns' ports: 'http': false, 'https': true
2019-04-27T07:22:21 [D] 'tftp' settings: 'enabled': https, 'tftp_connect_timeout': 10 (default), 'tftp_dns_timeout': 10 (default), 'tftp_read_timeout': 60 (default), 'tftproot': /srv/tftp
2019-04-27T07:22:21 [D] Providers ['dns_nsupdate'] are going to be configured for 'dns'
2019-04-27T07:22:21 [D] 'dns_nsupdate' settings: 'dns_key': /etc/bind/foreman.key, 'dns_server': ns0.mydomain, 'dns_ttl': 86400, 'use_provider': dns_nsupdate
2019-04-27T07:22:21 [I] Successfully initialized 'dns_nsupdate'
2019-04-27T07:22:21 [I] Successfully initialized 'dns'
grep dns /etc/foreman-installer/scenarios.d/foreman-answers.yaml
dns: true
dns_listen_on: https
dns_managed: true
dns_provider: nsupdate
dns_interface: enp8s0
dns_zone: free2air.net
dns_reverse:
dns_server: ns0.mydomain
dns_ttl: 86400
dns_tsig_keytab: "/etc/foreman-proxy/dns.keytab"
dns_tsig_principal: foremanproxy/foreman.mydomain@MYDOMAIN
dns_forwarders: []
freeipa_remove_dns: true
dns_alt_names: []
foreman_proxy::plugin::dns::infoblox: false
foreman_proxy::plugin::dns::powerdns: false
cat /etc/foreman-proxy/settings.d/dns.yml
# DNS management
:enabled: https
:use_provider: dns_nsupdate
cat /etc/foreman-proxy/settings.d/dns_nsupdate.yml
# Configuration file for 'nsupdate' dns provider
:dns_key: /etc/bind/foreman.key
:dns_server: ns0.mydomain
grep log /etc/foreman-proxy/settings.yml
# Uncomment and modify if you want to change the location of the log file or use STDOUT or SYSLOG values
:log_file: /var/log/foreman-proxy/proxy.log
# Uncomment and modify if you want to change the log level
:log_level: DEBUG
# The maximum size of a log file before it's rolled (in MiB)
# The maximum age of a log file before it's rolled (in seconds). Also accepts 'daily', 'weekly', or 'monthly'.
# Number of log files to keep
# Logging pattern for file-based loging
#:file_logging_pattern: '%d %.8X{request} [%.1l] %m'
# Logging pattern for syslog or journal loging
#:system_logging_pattern: '%.8X{request} [%.1l] %m'
:log_buffer: 2000
:log_buffer_errors: 1000
Thanks in advance for any suggestions or tips to investigate this further!
Adam.
