After what appears to be a successful build of a host, we have a series of Ansible roles that need to run. In past versions I was able to watch the progress under Monitor>Jobs> locate the host > click on host name down by status.
I’m expecting to see output when I view the black pane. It’s also unknown if the ansible roles are even running. I haven’t found the logs yet.
We noticed a problem in 1.24 with ansible being stuck. The solutions boils down to updating the ansible-core plugin from 3.0.1 to 3.0.2 ;however, this package seems to be only available from the 1.25 repo. (check out yum.theforeman.org)
I’ve detailed this solution in the following post: Katello/Foreman Ansible run jobs stuck in pending state
that seemed to have fixed at least getting the roles to run. However, now the problem is I had set a number of roles to run, and they aren’t all running
I’m new to Formean and have, based on this solution, upgraded foreman from 1.24.1 to 1.24.2.
However when i run an ansible role for a host, it still remains in pending state.
When viewing the running task details, it still gets stuck at 25%.
So I’m forced to abort the job.
Meanwhile, following is constantly written in the logging:
2020-02-24T12:04:06 [I|app|1247901f] Completed 200 OK in 67ms (Views: 30.7ms | ActiveRecord: 8.6ms)
2020-02-24T12:04:07 [I|app|15111d46] Started GET “/job_invocations/chart?id=16” for 10.16.8.1 at 2020-02-24 12:04:07 +0100
2020-02-24T12:04:07 [I|app|15111d46] Processing by JobInvocationsController#chart as JSON
2020-02-24T12:04:07 [I|app|15111d46] Parameters: {“id”=>“16”}
2020-02-24T12:04:07 [I|app|15111d46] Completed 200 OK in 67ms (Views: 0.3ms | ActiveRecord: 6.4ms)
2020-02-24T12:04:07 [I|app|8a6fe849] Started GET “/job_invocations/16?hosts_needs_refresh=&host_ids_needing_status_update%5B%5D=6&=1582542222853" for 10.16.8.1 at 2020-02-24 12:04:07 +0100
2020-02-24T12:04:07 [I|app|8a6fe849] Processing by JobInvocationsController#show as JS
2020-02-24T12:04:07 [I|app|8a6fe849] Parameters: {“hosts_needs_refresh”=>"", “host_ids_needing_status_update”=>[“6”], "”=>“1582542222853”, “id”=>“16”}
2020-02-24T12:04:07 [I|app|8a6fe849] Rendering /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-2.0.8/app/views/job_invocations/show.js.erb
2020-02-24T12:04:07 [I|app|8a6fe849] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-2.0.8/app/views/job_invocations/_host_status_td.html.erb (0.5ms)
2020-02-24T12:04:07 [I|app|8a6fe849] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/foreman_remote_execution-2.0.8/app/views/job_invocations/show.js.erb (36.7ms)
I’m also confused about the IP mentioned in the log.
It is the gateway for one of the interfaces I have added to my host, so why is it using this IP!
I hope someone can help me figuring out what might be wrong.
