Thanks for the report! looks like our fix for the issue has been incomplete. Opened Bug #28727: dns timeout setting is `[nil]` causing dns lookup to fail - Foreman to fix this correctly. Do you happen to have a db backup from 1.24.0 before you upgraded to 1.24.1?
Hi, I also made the “mistake” to upgrade to version 1.24.1. When I create a new host via the webinterface I get also the error:
**Oops, we're sorry but something went wrong** nil is not numeric
… Is there a workaround to get a machine deployed? thanks
yes, reset the dns_timeout
setting to default value (or give it any other value you wish - as long as it’s an array of integers)
can you also please confirm the value currently there is [nil]
