Humpf.
In fact, foreman-proxy does not want to start anymore.
It just started once after the upgrade, and now, it fails with the already reported error.
strange…
De : foreman-users@googlegroups.com [mailto:foreman-users@googlegroups.com] De la part de SCHAER Frederic Envoyé : jeudi 25 septembre 2014 19:05 À : foreman-users@googlegroups.com Objet : [PROVENANCE INTERNET] [foreman-users] foreman 1.6 puppet modules : /etc/foreman-proxy/settings.dHi,
I just attempted a migration from foreman 1.4.5 to 1.6.0 : I upgraded the foreman modules to the 1.6 version, and I had to create the settings.d directory manually for the puppet configuration to work correctly (I’m not using the foreman installer outside of puppet).
Since this dir was manually created, I did not chown the dir to the foreman-user, and this apparently prevented the foreman-proxy from starting, with this cryptic error displayed :
/usr/share/foreman-proxy/bin/…/lib/sinatra-patch.rb:22:in run!': private method
gsub’ called for false:FalseClass (NoMethodError)
from /usr/share/foreman-proxy/bin/smart-proxy:44
Was this expected ?
Shouldn’t the settings.d directory be managed either by the RPMs or the puppet modules ?
Appart from that, upgrade went smoothly , thanks for the great work :]
regards
To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.commailto:foreman-users+unsubscribe@googlegroups.com.
To post to this group, send email to foreman-users@googlegroups.commailto:foreman-users@googlegroups.com.
