Hey,
some days ago I updated foreman from version 1.9.1 to 1.9.2
Update process:
- stop apache (I use passenger for foreman/puppet)
- apt-get upgrade
- foreman-rake db:migrate
- foreman-rake db:seed
- foreman-rake tmp:cache:clear
- foreman-rake tmp:sessions:clear
- start apache again
With 1.9.2 it is not possible to import/update puppet classes.
Error message:
undefined method `values' for []:Array
Did I forget anything after update? Or what could be the reason for this? I
downgraded foreman back to 1.9.1 and it is possible to
Best regards,
thomas.
trace:
NoMethodError
*undefined method values' for []:Array* /usr/share/foreman/app/services/puppet_class_importer.rb:77:in
new_classes_for'
/usr/share/foreman/app/services/puppet_class_importer.rb:38:in changes' /usr/share/foreman/app/controllers/concerns/foreman/controller/environments.rb:11:in
import_environments'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_controller/metal/implicit_render.rb:4:in
send_action' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/abstract_controller/base.rb:167:in
process_action'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_controller/metal/rendering.rb:10:in
process_action' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/abstract_controller/callbacks.rb:18:in
block in process_action'
/usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:638:in
block (4 levels) in _run__3696272407703915519__process_action__2609977037389602546__callbacks' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:215:in
block in _conditional_callback_around_7731'
/usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:326:in
around' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:310:in
_callback_around_2449'
/usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:214:in
_conditional_callback_around_7731' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:626:in
block (3 levels) in
block in _conditional_callback_around_7730' /usr/share/foreman/app/controllers/concerns/application_shared.rb:13:in
set_timezone'
_conditional_callback_around_7730' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:625:in
block (2 levels) in
block in _conditional_callback_around_7729' /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in
clear_thread'
_conditional_callback_around_7729' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:448:in
block in
block in _conditional_callback_around_7728' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:326:in
around'
_callback_around_13' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:214:in
/usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:414:in
_run__3696272407703915519__process_action__2609977037389602546__callbacks' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:405:in
__run_callback'
/usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:385:in
_run_process_action_callbacks' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:81:in
run_callbacks'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/abstract_controller/callbacks.rb:17:in
process_action' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_controller/metal/rescue.rb:29:in
process_action'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_controller/metal/instrumentation.rb:30:in
block in process_action' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/notifications.rb:123:in
block in instrument'
/usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/notifications/instrumenter.rb:20:in
instrument' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/notifications.rb:123:in
instrument'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_controller/metal/instrumentation.rb:29:in
process_action' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_controller/metal/params_wrapper.rb:207:in
process_action'
/usr/share/foreman/vendor/ruby/1.9.1/gems/activerecord-3.2.21/lib/active_record/railties/controller_runtime.rb:18:in
process_action' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/abstract_controller/base.rb:121:in
process'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/abstract_controller/rendering.rb:45:in
process' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_controller/metal.rb:203:in
dispatch'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_controller/metal/rack_delegation.rb:14:in
dispatch' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_controller/metal.rb:246:in
block in action'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/routing/route_set.rb:73:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/routing/route_set.rb:73:in
dispatch'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/routing/route_set.rb:36:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/journey-1.0.4/lib/journey/router.rb:68:in
block in call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/journey-1.0.4/lib/journey/router.rb:56:in
each' /usr/share/foreman/vendor/ruby/1.9.1/gems/journey-1.0.4/lib/journey/router.rb:56:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/routing/route_set.rb:608:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/apipie-rails-0.2.6/lib/apipie/extractor/recorder.rb:97:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/apipie-rails-0.2.6/lib/apipie/middleware/checksum_in_headers.rb:27:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/best_standards_support.rb:17:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/etag.rb:23:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/conditionalget.rb:25:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/head.rb:14:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/params_parser.rb:21:in
call'
/usr/share/foreman/lib/middleware/catch_json_parse_errors.rb:9:in call' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/flash.rb:242:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/session/abstract/id.rb:210:in
context' /usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/session/abstract/id.rb:205:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/cookies.rb:341:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/activerecord-3.2.21/lib/active_record/query_cache.rb:64:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/activerecord-3.2.21/lib/active_record/connection_adapters/abstract/connection_pool.rb:479:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/callbacks.rb:28:in
block in call'
_run__1625289529350273356__call__106148623623187546__callbacks' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:405:in
__run_callback'
_run_call_callbacks' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/callbacks.rb:81:in
run_callbacks'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/callbacks.rb:27:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/remote_ip.rb:31:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/debug_exceptions.rb:16:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/show_exceptions.rb:56:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/railties-3.2.21/lib/rails/rack/logger.rb:32:in
call_app' /usr/share/foreman/vendor/ruby/1.9.1/gems/railties-3.2.21/lib/rails/rack/logger.rb:18:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/request_id.rb:22:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/methodoverride.rb:21:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/runtime.rb:17:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/activesupport-3.2.21/lib/active_support/cache/strategy/local_cache.rb:72:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/lock.rb:15:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/actionpack-3.2.21/lib/action_dispatch/middleware/static.rb:83:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/rack-cache-1.2/lib/rack/cache/context.rb:136:in
forward' /usr/share/foreman/vendor/ruby/1.9.1/gems/rack-cache-1.2/lib/rack/cache/context.rb:245:in
fetch'
/usr/share/foreman/vendor/ruby/1.9.1/gems/rack-cache-1.2/lib/rack/cache/context.rb:185:in
lookup' /usr/share/foreman/vendor/ruby/1.9.1/gems/rack-cache-1.2/lib/rack/cache/context.rb:66:in
call!'
/usr/share/foreman/vendor/ruby/1.9.1/gems/rack-cache-1.2/lib/rack/cache/context.rb:51:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/railties-3.2.21/lib/rails/engine.rb:484:in
call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/railties-3.2.21/lib/rails/application.rb:231:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/railties-3.2.21/lib/rails/railtie/configurable.rb:30:in
method_missing'
/usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/builder.rb:134:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/urlmap.rb:64:in
block in call'
/usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/urlmap.rb:49:in
each' /usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.7/lib/rack/urlmap.rb:49:in
call'
/usr/lib/ruby/vendor_ruby/phusion_passenger/rack/thread_handler_extension.rb:77:in
process_request' /usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler/thread_handler.rb:142:in
accept_and_process_next_request'
/usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler/thread_handler.rb:110:in
main_loop' /usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler.rb:448:in
block (3 levels) in start_threads'
/usr/share/foreman/vendor/ruby/1.9.1/gems/logging-2.0.0/lib/logging/diagnostic_context.rb:448:in
call' /usr/share/foreman/vendor/ruby/1.9.1/gems/logging-2.0.0/lib/logging/diagnostic_context.rb:448:in
block in create_with_logging_context'
