Make this post a wiki
Roles
- Release Owner: @upadhyeammit
- Release Engineer: @pcreech
- Installer Maintainer: @ekohl
Manual updates: 2022-02-23
Release Engineer
- Update manual if applicable for any additional installation steps
- Update release notes section in the manual:
- Release notes: bullet point list by category of all changes, include link to bug numbers. You can auto-generate changes using the release notes script.
- CLI release notes are taken from the hammer-cli and hammer-cli-foreman changelogs
- Link to installer changelogs and note versions being used
- Update installer options section using the get-params script if any changes were made in the installer or installer modules (after new packages have been released)
- Update the apipie docs and place those in the foreman/3.0/apidoc directory if any changes were made to the API
Preparing code: 2022-02-23
Make patch releases of installer modules that have important changes
- Branch to MAJ.MIN-stable if recent changes to the module aren’t suitable for patch (x.y.z) release
Release Owner
- Add a new Redmine version for the next minor, unless the series is EOL. Be sure the version is set to sharing with subprojects.
- Remove/change target version field for any open Redmine tickets assigned to the release still (next minor, unset it or reject)
- Ensure that code in git matches issues fixed in 3.0.2 in redmine. issues.rb can be used to generate a comparison between the two.
- Change Redmine version 3.0.2 state to Closed
Tagging a release: 2022-02-23
Release Owner
- In foreman 3.0-stable:
- Make sure test_3_0_stable is green
Tag the release using tag.sh
tag.sh 3.0.2 && git push upstream 3.0-stable --follow-tags
- In smart-proxy 3.0-stable:
- Make sure test_proxy_3_0_stable is green
- In foreman-selinux 3.0-stable:
- In foreman-installer 3.0-stable:
- Run the Jenkins Tarballs Release to create tarballs
Release Engineer
- Update release version similar to here
- Sign Tarballs
Note: If for some reason there was an issue with the tarballs that required uploading new tarballs, CDN cache should be invalidated so that the builders use the updated tarballs.
Packaging a release: 2022-02-23
Note it is considered good practice to release on a day when the next day is a working day. This means no releases on Fridays or on the day before a holiday.
Release Engineer
- Update foreman-packaging branches
- Wait for packages to be built
Tag
foreman-release
intoforeman-client-3.0-rhel7
andforeman-client-3.0-el8
, as this doesn’t happen automatically for those tags.-
koji tag-build foreman-client-3.0-rhel7 foreman-release-3.0.2-1.el7
koji tag-build foreman-client-3.0-el8 foreman-release-3.0.2-1.el8
- Check for outstanding PRs against 3.0 packaging, and merge if possible:
- Sign the RPMs in the release
Sign RPMs for client repos (call scripts with
PROJECT=client
Kick off the release pipeline by calling
release_pipeline
Kick off the client pipeline by calling
PROJECT=client release_pipeline
- Kick off the plugins pipeline by calling plugins_pipeline
After the packages have been released
Release Owner
- Update the versions on the website in version and latest news
- Announce the release on Discourse
- Update the topic in #theforeman channel on Freenode
- Share the release announcement on twitter
- Release pipeline will trigger foreman-plugins-3.0-deb-test-pipeline and foreman-plugins-3.0-rpm-test-pipeline. These don’t block releases but can be used to understand known issues around plugin compatibility with Foreman 3.0.
