When trying to view certificates from Foreman, the following error message shows up in the webgui:
Failure: ERF50-5345 [Foreman::WrappedException]: Unable to connect ([ProxyAPI::ProxyException]: ERF12-5356 [ProxyAPI::ProxyException]: Unable to get PuppetCA certificates ([RestClient::NotAcceptable]: 406 Not Acceptable) for proxy *hostname*:8443/puppet/ca)
and we are not able to view certificates or approve new requests.
I should be able to view existing certificates as well as approve certificate requests through Foreman
Puppetserver: 6.7.2 , Foreman: 1.22.2 , Proxy: Maybe N/A (not sure how to find this) )
N/A (?)
Ubuntu 16.04.6 LTS
I have been troubleshooting this a bit. Im new to Linux admin, puppet and foreman, but also eager to learn of course. Below are the logs i found with relevant info, and also the auth.conf.
Puppet and foreman are running on the same server.
/var/log/foreman-proxy/proxy.log
2021-07-08T09:30:47 5d795038 [E] Failed to list certificates: Failed to query Puppet CA search v1 API: 403 Forbidden request: /puppet-ca/v1/certificate_statuses/foreman (method :get). Please see the server logs for details.
/var/log/foreman/production.log
2021-07-08T09:30:47 [I|app|f81877a8] Started GET "/smart_proxies/1-*hostname*/puppetca/1-*hostname*/expiry" for 1.2.3.4 at 2021-07-08 09:30:47 +0200
2021-07-08T09:30:47 [I|app|f81877a8] Processing by PuppetcaController#expiry as HTML
2021-07-08T09:30:47 [I|app|f81877a8] Parameters: {"smart_proxy_id"=>"1-*hostname*", "id"=>"1-*hostname*"}
2021-07-08T09:30:47 [I|app|f81877a8] Current user set to me@user.com (admin)
2021-07-08T09:30:47 [W|app|f81877a8] Failed to expiry
| Foreman::WrappedException: ERF50-5345 [Foreman::WrappedException]: Unable to connect ([ProxyAPI::ProxyException]: ERF12-5356 [ProxyAPI::ProxyException]: Unable to get PuppetCA certificates ([RestClient::NotAcceptable]: 406 Not Acceptable) for proxy https://*hostname*:8443/puppet/ca)
/var/log/puppetlabs/puppetserver/puppetserver-access.log
(2.3.4.5 puppetmaster ip)
2.3.4.5 - - [08/Jul/2021:09:30:47 +0200] "GET /puppet-ca/v1/certificate_statuses/foreman HTTP/1.1" 403 116 "-" "Ruby" 7 - -
2.3.4.5 - - [08/Jul/2021:09:30:47 +0200] "GET /puppet-ca/v1/certificate_statuses/foreman HTTP/1.1" 403 116 "-" "Ruby" 2 - -
/var/log/puppetlabs/puppetserver/puppetserver.log
2021-07-08T09:30:47.120+02:00 ERROR [qtp600582592-143478] [p.t.a.rules] Forbidden request: 2.3.4.5 access to /puppet-ca/v1/certificate_statuses/foreman (method :get) (authenticated: false) denied by rule 'certificate_statuses'.
2021-07-08T09:30:47.282+02:00 ERROR [qtp600582592-139132] [p.t.a.rules] Forbidden request: 2.3.4.5 access to /puppet-ca/v1/certificate_statuses/foreman (method :get) (authenticated: false) denied by rule 'certificate_statuses'.
2021-07-08T09:30:47.558+02:00 ERROR [qtp600582592-143590] [p.t.a.rules] Forbidden request: 2.3.4.5 access to /puppet-ca/v1/certificate_statuses/foreman (method :get) (authenticated: false) denied by rule 'certificate_statuses'.
I also noticed the following in /etc/puppetlabs/puppetserver/conf.d/auth.conf
authorization: {
version: 1
rules: [
"allow": [
"localhost",
"2.3.4.5",
"hostname"
"match-request": {
"method": [
"get",
"put",
"delete"
"path": "/puppet-ca/v1/certificate_status/",
"query-params": {},
"type": "path"
"name": "certificate_status",
"sort-order": 200
Reading the documentation for auth.conf i see that there is a possibility of using allow-unauthenticated
, but im wondering why it isnt authenticated.
Can anyone give me a hint as to which direction to go, or what more to check to see?
I have not seen other problems with the installation. I dont know the history as the whole environment is a hand-me-down, but im learning a lot from this…
