I am using foreman infra to provision sparc hosts with solaris 10.
Everything works fine except the patches are not getting installed from the
Patches nfs share, shared from foreman-proxy. But, If I use nfs share from
a old Solaris machine, Patches update works just fine.
Following are just the logs of a random patch add which behaves differently
for same patch folder shared from a solaris box and a linux box. Patch
update from a Linux share doesnt even detect that package is installed. The
same is the case with valid packages, for which patchupdate doesnt work.
Trying from a solaris-10 machine's nfs share
$ patchadd ~/Patches1/sparc/5.10/10_Recommended/patches/120900-04
Validating patches…
Loading patches installed on the system…
Done!
Loading patches requested to install.
Done!
The following requested patches are already installed on the system
Requested patch 120900-04 is already installed on the system.
No patches to dependency check.
Trying from Foreman-proxy's nfs Share (rhel6 box)
patchadd ~/Patches/sparc/5.10/10_Recommended/patches/120900-04
Validating patches…
Done!
Done!
The following requested patches do not update any packages installed on the
system
No Packages from patch 120900-04 are installed on the system.
No patches to dependency check. ela4-db101.prod.linkedin.com:nsonawan[102] ~ $
my exports options on rhel6 foreman-proxy look like this
differently for same patch folder shared from a solaris box and a linux
box. Patch update from a Linux share doesnt even detect that package is
installed. The same is the case with valid packages, for which patchupdate
doesnt work.
Trying from a solaris-10 machine’s nfs share
Validating patches…
Done!
Done!
Trying from Foreman-proxy’s nfs Share (rhel6 box)
Validating patches…
Done!
Done!
the system
