I finished testing of the foreman-debug script. Here is the candidate:
This is how it looks like:
root@squeeze-foreman:~# ./foreman-debug -h
./foreman-debug - configuration and log data collector
USAGE: ./foreman-debug [options]
Collects configuration and log data for Foreman, Smart Proxies, backend
services and system information while removing security information like
passwords, tokens and keys.
This program can be used on Foreman instance, Smart Proxy instances or
backend services separatly.
OPTIONS:
-d DIR Directory to place the tarball in (default /tmp/foreman-XYZ)
-g Skip generic info (CPU, memory, firewall etc.)
-a Do not generate a tarball from the resulting directory
-m Maximum lines to keep for each file (default 5000)
-j PRG Filter with provided program when creating a tarball
-q Quiet mode
-v Verbose mode
-h Shows this message
A debug file has been created: /tmp/foreman-debug-5jEuX.tar.xz (23708 bytes)
Attaching example tarball, please review and discuss. Missing something?
Found some sensitive data in it? Not working properly on your distro?
Feel free to send me a patch or comment.
> Hello,
> https://gist.github.com/lzap/5460551
> OPTIONS:
> -q Quiet mode
> -v Verbose mode
fyi… this is what is katello.
Usage: katello-debug [options] command
–dir [DIRECTORY] Directory to place the tarball.
Defaults to /tmp
–notar Do not generate a tar file, just
copy the files to target dir
–help Display help and exit
the notar seems to be missing
> And this is how it works:
> HOSTNAME: squeeze-foreman.virtual.lan
> OS: debian
> RELEASE: 6.0.7
> FOREMAN: 1.1-1
> RUBY: ruby 1.8.7 (2010-08-16 patchlevel 302) [x86_64-linux]
> PUPPET: 3.1.1
What is the hash here? katello-debug uses a timestamp. That seems a bit
nicer when there are many of these flowing around
> Hello,
> OPTIONS:
> -q Quiet mode
> -v Verbose mode
> OS: debian
> RELEASE: 6.0.7
> FOREMAN: 1.1-1
> PUPPET: 3.1.1
> bytes)
its a great start!
while browsing a bit on the tar, i was missing foreman logs? and pg
commands failed.
thanks!
Ohad
On Thu, Apr 25, 2013 at 6:25 PM, Lukas Zapletal wrote:
Seems good, one thing I noticed - gem list did't show anything. Note that on
debian you can find gem1.8 and gem1.9.1 and /usr/bin/gem is just symlink to one
of them (via alternatives).
On Thursday 25 of April 2013 17:25:44 Lukas Zapletal wrote:
> Hello,
> OPTIONS:
> -q Quiet mode
> -v Verbose mode
> OS: debian
> RELEASE: 6.0.7
> FOREMAN: 1.1-1
> PUPPET: 3.1.1
> bytes)
Yeah I heavily inspired from Katello and we are compatible, except for
simplicity I am not able to parse long options. I am using bash getopt
which only accepts short options, so foreman options are:
> --dir [DIRECTORY] Directory to place the tarball.
> --notar Do not generate a tar file,
> --help Display help and exit
So it is -a instead --notar.
I wanted the script to KISS. :-X
My version is more simple compared to the Ruby version from Katello,
maybe folks could adopt it for katello as well once I finish with it.
On Thu, Apr 25, 2013 at 01:43:55PM -0400, Bryan Kearney wrote:
On Thu, Apr 25, 2013 at 05:25:44PM +0200, Lukas Zapletal wrote:
> Hello,
> OPTIONS:
> -q Quiet mode
> -v Verbose mode
> OS: debian
> RELEASE: 6.0.7
> FOREMAN: 1.1-1
> PUPPET: 3.1.1
> Later,
> Lukas "lzap" Zapletal
> irc: lzap #theforeman
> You received this message because you are subscribed to the Google Groups "foreman-dev" group.
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com.
> For more options, visit https://groups.google.com/groups/opt_out.
Gems are vendored on the Debian packages - use bundle exec gem list in the
foreman dir.
Greg
On 26 April 2013 07:24, Marek Hulan wrote:
Seems good, one thing I noticed - gem list did’t show anything. Note that
on
to one
Should be there, I think the instance just did not get started. Will
investigate.
On Thu, Apr 25, 2013 at 08:32:42PM +0300, Ohad Levy wrote:
> its a great start!
> commands failed.
I dont think it makes sense to do bundle exec gem list since it should
give the same output as bundle --local.
So I am going to remove gem list command, okay?
LZ
> > on
> > to one
> foreman dir.
> Greg
Ok my testing instance is sqlite and log is not in /var/log/foreman
Anyone willing to run the script on a non-production instance (but
package based installation)?
I will send one more tarball, hopefully with more info.
> > its a great start!
> > commands failed.
> investigate.
