Greg,
It seems like there are a few of us on the list who are having trouble
getting this cool plugin you've built loaded up. I thought about filing an
issue on GitHub but thought maybe this is my problem and not the plugins.
I decided to post a new thread instead of hijacking the other's.
I've got a git-gist of junk regarding my particular problem [1], and I'm
wondering if it all comes down to GEM_PATH and Gem Environment. It seems
that all the passenger stuff is using Ruby 1.9.x gems, but my host
environment for both Foreman User and Root is all using Ruby 1.8.
Is there a quick fix on this?
Many thanks!
[1] https://gist.github.com/salderma/6705450
> Greg,
> an issue on GitHub but thought maybe this is my problem and not the
> plugins. I decided to post a new thread instead of hijacking the other's.
> seems that all the passenger stuff is using Ruby 1.9.x gems, but my host
Yes, you should use "scl enable ruby193" to switch into the 1.9
environment. See
Foreman :: Manual.
> Many thanks!
I'd ignore the stuff installed now into the 1.8 environment now (but
maybe it should be removed via gem uninstall some time). I'd begin by
removing Gemfile and Gemfile.lock, only leave Gemfile.in (as provided by
our packages). We don't actually use bundler directly in the RPMs now.
Next, install the dependency and gem with:
scl enable ruby193 'gem install --ignore-dependencies
foreman_default_hostgroup'
rpm -Uvh
http://yum.theforeman.org/plugins/1.2/el6/x86_64/ruby193-rubygem-deface-0.7.2-6.el6.noarch.rpm
And configure Foreman so it finds it:
echo "gem 'foreman_default_hostgroup'" >
/usr/share/foreman/bundler.d/foreman_default_hostgroup.rb
You can then be able to restart httpd and it should load.
I'd like to get this packaged as an RPM for our plugins repo, but it
needs a rewrite before we can really support it (e.g. with 1.3).
Cheers,
On 27/09/13 19:03, Sean Alderman wrote:
Dominic Cleal
Red Hat Engineering
I forgot to say, keep an eye on this list to see which plugins have RPMs
built (suggestions gladly taken):
http://projects.theforeman.org/projects/foreman/wiki/List_of_Plugins
And this for installing them:
http://projects.theforeman.org/projects/foreman/wiki/How_to_Install_a_Plugin
>> Greg,
> environment. See
> http://theforeman.org/manuals/1.2/index.html#3.3.2SoftwareCollections.
>> Many thanks!
> rpm -Uvh
Dominic Cleal
Red Hat Engineering
Thanks for reply with th install stuff, Dominic, SCL still confuses the
hell out of me
I'm really hoping to get a rewrite of default_hostgroup done over the
weekend. We'll see how it goes.
Many thanks! I'm with Greg, but I'm sure he knows tons more about ruby
than I do. All seems to be installed and working.
I'm not sure where the ruby 1.8 stuff came from, perhaps lingering from an
old version of foreman that was installed but not running when I
commandeered our Foreman server.
> hell out of me :P
Ok, 1.3-compatible version is up on plugin Github repo[1]. Give it a test.
Dominic, any chance you could give the code a look-over.
This is a nice simple plugin, so I'm hoping to use it as a starting point
for figuring out a good way to add tests to a plugin. We'll see how that
goes
Greg
[1]https://github.com/GregSutcliffe/foreman_default_hostgroup/tree/1.3
hell out of me
I’m really hoping to get a rewrite of default_hostgroup done over the
weekend. We’ll see how it goes.
Just a heads up for those who haven't already spotted it - the 1.3 version
of the plugin got packaged for RPM a while back. Give it a spin
http://yum.theforeman.org/plugins/1.3/f19/x86_64/rubygem-foreman_default_hostgroup-1.0.0-1.fc19.noarch.rpm
Greg
Though please use the repo appropriate for your OS, not just the F19 RPM
On 21/10/13 15:26, Greg Sutcliffe wrote:
> test. Dominic, any chance you could give the code a look-over.
> version of the plugin got packaged for RPM a while back. Give it a spin :)
Dominic Cleal
Red Hat Engineering
