I upgraded to version 1.3 and now the discovery process is not working.
Both /tmp/proxy-discovery.err & /tmp/proxy-discovery.log are empty.
Would it be something to do with the view not updating in the UI?
I'll be trying to get this updated for the end of the week, so as Ohad
says, any feedback/logs/errors is much appreciated!
Greg
Can you provide a bit more info about whats broken? do you get an error
message etc?
thanks!
Ohad
I upgraded to version 1.3 and now the discovery process is not working.Both /tmp/proxy-discovery.err & /tmp/proxy-discovery.log are empty.
"Foreman users" group.
Ok, so in version 1.2 i had configured foreman to use SSL certificates, but
also called "service foreman start" which started my foreman service
running on port 3000 also.
This allowed the discovery image to register using foreman.ip=<addr>:3000
in the PXE Default File. I was also able to go to http://<addr>:3000 in
browser and it displayed the UI.
Now in version 1.3, it appears to always redirect me to the HTTPS site and
i've never been able to get the discovery script to work using SSL?
So a bit more digging gives me the following error:
Response: Failed to import facts: uninitialized constant
Host::Discovered::Puppet
I believe the error comes from
/foreman_discovery/app/models/host/discovered.rb Line 30
Yep, you are correct, feel free to remove 30-32 and tell us if it works?
Thanks!
Ohad
Host::Discovered::PuppetOn Wednesday, October 16, 2013 8:16:35 PM UTC+1, Alan Sergeant wrote:
but also called “service foreman start” which started my foreman service
foreman.ip=:3000 in the PXE Default File. I was also able to go to
http://:3000 in browser and it displayed the UI.Now in version 1.3, it appears to always redirect me to the HTTPS site
and i’ve never been able to get the discovery script to work using SSL?On Wednesday, October 16, 2013 3:50:10 PM UTC+1, Greg Sutcliffe wrote:
On 16 October 2013 15:32, Alan Sergeant aserg...@gmail.com wrote:
I upgraded to version 1.3 and now the discovery process is not working.I’ll be trying to get this updated for the end of the week, so as Ohad
says, any feedback/logs/errors is much appreciated!Greg
Ok, i tried it and it didn't work. I think due to the fact the smart-proxy
isn't outputting a hash when <ip>:8443/facts is called.
The output from this is:
{"id":"root","is_virtual":"true","network_lo":"127.0.0.0","physicalprocessorcount":1,"sshdsakey":"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","operatingsystem":"Ubuntu","netmask_lo":"255.0.0.0","ipaddress_eth1":"10.0.1.12","path":"/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games","hostname":"ubuntu","lsbdistrelease":"12.04","ipaddress_lo":"127.0.0.1","virtual":"virtualbox","kernel":"Linux","network_eth0":"10.55.164.0","rubysitedir":"/usr/local/lib/site_ruby/1.8","netmask":"255.255.255.0","netmask_eth1":"255.255.255.0","processor0":"Intel® Core™ i5 CPU M 540 @ 2.53GHz","macaddress_eth1":"08:00:27:43:fa:ae","augeasversion":"0.10.0","operatingsystemrelease":"12.04","memoryfree":"382.83 MB","uniqueid":"007f0101","boardmanufacturer":"Oracle Corporation","swapfree":"508.00 MB","ipaddress_eth0":"10.55.164.211","kernelmajversion":"3.8","hardwaremodel":"x86_64","uptime_days":0,"domain":"dhcp.bfsl.sap.corp","swapsize":"508.00 MB","selinux":"false","architecture":"amd64","uptime_hours":2,"boardserialnumber":"0","fqdn":"ubuntu.dhcp.bfsl.sap.corp","interfaces":"eth0,eth1,lo","productname":"VirtualBox","boardproductname":"VirtualBox","sshecdsakey":"AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBHGElwArbd38NTPVBr2pzXo5FxUOu+ceYGmW2ciscAPcilkUaMEYdajLoQbkZinLGFkGHAxyYiW5z8b1NCTfabw=","sshrsakey":"AAAAB3NzaC1yc2EAAAADAQABAAABAQDZ7hbMdUz6Yg+GyUs/h/2kHGafNAUDW9yZ6DlD4ZhXpsSuu6lTKh/wSihJXWr2mnv5T46Np5VUZCsRC9fa1YRShqXm7nRbvqt5s5wJhCQ0K3NHbg7vEKa+8CgT0N/YC2KrPC7Zce58360OytdB6+i80xbTgNTVlOriFvPiqv2Hn8dvJgo7123Ywluz7AT4aVpFCLEiFZ03HLaJYZFfhtLlwYrqH6kfB7zXCS4hlnq7eyd5wW2wDYukZ8Nd/7q6KT90Mep+6usqiw8lSmJuYB9kwixl+USO6zK6wxbNsieX5H1GoNDxH8jUOc3khvGJ/vo/AeKOfFDGpRg9W+6BjHfV","serialnumber":"0","netmask_eth0":"255.255.255.0","macaddress_eth0":"08:00:27:4d:fd:32","lsbdistdescription":"Ubuntu 12.04.3 LTS","rubyversion":"1.8.7","facterversion":"1.6.5","memorytotal":"490.93 MB","timezone":"BST","ipaddress":"10.55.164.211","kernelrelease":"3.8.0-29-generic","memorysize":"490.93 MB","puppetversion":"2.7.11","macaddress":"08:00:27:4d:fd:32","kernelversion":"3.8.0","ps":"ps -ef","uptime_seconds":8031,"uptime":"2:13 hours","processorcount":"1","osfamily":"Debian","network_eth1":"10.0.1.0","lsbdistid":"Ubuntu","lsbdistcodename":"precise","type":"Other","lsbmajdistrelease":"12","hardwareisa":"x86_64","manufacturer":"innotek GmbH"}
I also tried removing the case statement and simply using:
name = facts.values["macaddress_eth0"].downcase.gsub(/:/,'')
values = facts.values
This returns can't convert String into Integer. Error comes from the name
variable i think?
Ok so i managed to get it to show in the UI, the only caveat is i haven't
been able to get the facts to show.
Only method I change was this:
def self.importHostAndFacts data
facts = data
name = facts["macaddress_eth0"].downcase.gsub(/:/,'')
values = facts
# filter facts
values.reject!{|k,v| k =~
/kernel|operatingsystem|osfamily|ruby|path|time|swap|free|fil$
if name
h = ::Host::Discovered.find_by_name name
end
h ||= Host.new :name => name, :type => "Host::Discovered"
h.type = "Host::Discovered"
h.mac = values["macaddress_eth0"].downcase
if SETTINGS[:locations_enabled]
begin
h.location = (Location.find_by_name Setting[:discovery_location])
>> Location.first
rescue
h.location = Location.first
end
end
if SETTINGS[:organizations_enabled]
begin
h.organization = (Organization.find_by_name
Setting[:discovery_organization]) || Or$
rescue
h.organization = Organization.first
end
end
h.save if h.new_record?
h.importFacts(name, values)
end
Got it fully working… file attached
discovered.rb (3.22 KB)
I should say it does require a new discovery image, with the latest
foreman_proxy code
Never done that before but i've given it a go… hopefully it worked
The method that Discovery hooks into in Foreman Core (ImportHostAndFacts)
has changed significantly in 1.3, so I expect the plugin will need to match
that. I'll try to take a look at it this afternoon
Thanks for your feedback so far, saves me a lot of time tracking down the
error
name = facts.values[“macaddress_eth0”].downcase.gsub(/:/,’’)
values = facts.valuesThis returns can’t convert String into Integer. Error comes from the name
variable i think?
Thanks Alan! would you mind sending it as PR to the discovery repo?
thanks!
Ohad
On Thursday, October 17, 2013 1:50:12 PM UTC+1, Alan Sergeant wrote:
Ok so i managed to get it to show in the UI, the only caveat is i haven’t
Only method I change was this:def self.importHostAndFacts data
facts = data
name = facts[“macaddress_eth0”].**downcase.gsub(/:/,’’)
values = facts# filter facts values.reject!{|k,v| k =~ /kernel|operatingsystem|**
osfamily>ruby>path>time>swap>**free|fil$
if name h = ::Host::Discovered.find_by_**name name end h ||= Host.new :name => name, :type => "Host::Discovered" h.type = "Host::Discovered" h.mac = values["macaddress_eth0"].**downcase if SETTINGS[:locations_enabled] begin h.location = (Location.find_by_name Setting[:discovery_location])
Location.first
rescue
end
end
if SETTINGS[:organizations_**enabled]
begin
h.organization = (Organization.find_by_name Setting[:discovery_**organization])Or$
rescue
end
endh.save if h.new_record? h.importFacts(name, values)
end
On Thursday, October 17, 2013 10:54:28 AM UTC+1, Greg Sutcliffe wrote:
name = facts.values[“macaddress_eth0”**].downcase.gsub(/:/,’’)
name variable i think?The method that Discovery hooks into in Foreman Core
(ImportHostAndFacts) has changed significantly in 1.3, so I expect the
plugin will need to match that. I’ll try to take a look at it this
afternoonThanks for your feedback so far, saves me a lot of time tracking down
the error–
Indeed it did, thanks! Let's move patch discussion to the Pull Request
Greg
Never done that before but i’ve given it a go… hopefully it worked
