DevOps Freelance Opportunity
Dear Foreman Community, anyone keen to explore freelance opportunity to help install and configure Foreman to manage 5 Linux workstations?
I can be reached directly at richwoon@gmail.com
Thanks. Only 1 company offered to do it so far. I also wanna explore all options. I need to get 3 quotes.
Not to discourage your efforts, but using Foreman to manage just 5 workstations sounds like it is potentially overkill (unless you plan that as a POC that will expand to a larger scale if successful).
As you can see in the professional services, there are not many companies that specialize in Foreman consulting work so I’m not sure if you’ll manage to get 3 offers, especially for such a small scale setup.
Hi Richard,
If you are still on the lookout for some help I would be glad to help you out, as what you are wanting done is well within my area of expertise.
You can reach me on andrewjohnson.56782@gmail.com
Cheers and Have a great day ahead,
Andrew
Hi Andrew,
Awesome, will contact you directly.
Only ATIX provided us with 1 quote. We will definitely send our engineers for ATIX training. Thanks for the advise
