I use foreman 1.4.0~rc1-1, Ubuntu 12.04
I create follow class.
class tp_test {
file {'testfile':
path => '/tmp/testfile',
ensure => present,
mode => 0640,
content => "I'm a test file.",
Import runs fine via GUI: Configure -> puppet classes -> Import from …
I don't assign this class to any host.
Now I change this file:
class tp_test {
file {'testfile':
ensure => present,
mode => 0644,
content => "Another mode and content",
Again to try an import: Configure -> puppet classes -> Import from …
Result: No changes to your enviroments detected.
I tried it on a console too:
- delete class tp_test via foreman gui.
- import class
root@myhost:/usr/share/foreman# RAILS_ENV=production rake
puppet:import:puppet_classes
Evaluating possible changes to your installation
Scheduled changes to your environment
New environments
[deprecated] I18n.enforce_available_locales will default to true in the
future. If you really want to skip validation of your locale you can set
I18n.enforce_available_locales = false to avoid this message.
production : tp_test
Updated environments
Delete environments
Proceed with these modifications? <yes|no> yes
Import complete
- change content of file and run import again
No changes detected
What have I to change in my setup, or is this a bug?
Best regards,
thomas.
That's correct behaviour - as far as Foreman's concerned, the class
hasn't changed in a meaningful way.
Foreman only records the class names, parameters and default values.
Since you haven't changed how the class looks externally, no import to
Foreman is required, and it won't record any changes.
However Puppet will pick up the change and should correctly change the
mode and file content on the next checkin.
Dominic Cleal
Red Hat Engineering
class tp_test {
file {‘testfile’:
path => ‘/tmp/testfile’,
ensure => present,
mode => 0640,
content => “I’m a test file.”,
I don’t assign this class to any host.
class tp_test {
file {‘testfile’:
ensure => present,
mode => 0644,
content => “Another mode and content”,
- import class
New environments
Delete environments
Import complete
No changes detected
Best regards,
thomas.
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com
