Hey Everyone,
I'm trying to install foreman but when i run the installer i get a bunch of
these messages, does anyone know what the problem coulde be?
foreman-installer
Parameter foreman-foreman-url invalid: ::foreman::params::foreman_url must
match one of (?-mix:^https?://)
Parameter foreman-puppetrun invalid: "::foreman::params::puppetrun" is not
a valid boolean, "::foreman::params::puppetrun" is not a valid boolean
Parameter foreman-unattended invalid: "::foreman::params::unattended" is
not a valid boolean
Parameter foreman-authentication invalid:
"::foreman::params::authentication" is not a valid boolean
Parameter foreman-passenger invalid: "::foreman::params::passenger" is not
a valid boolean, "::foreman::params::passenger" is not a valid boolean
Parameter foreman-use-vhost invalid: "::foreman::params::use_vhost" is not
a valid boolean
Parameter foreman-ssl invalid: "::foreman::params::ssl" is not a valid
boolean
Parameter foreman-configure-epel-repo invalid:
"::foreman::params::configure_epel_repo" is not a valid boolean
Parameter foreman-configure-scl-repo invalid:
"::foreman::params::configure_scl_repo" is not a valid boolean
Parameter foreman-selinux invalid: "::foreman::params::selinux" is not a
valid boolean
Parameter foreman-gpgcheck invalid: "::foreman::params::gpgcheck" is not a
valid boolean
Kind regards
Hi Wim,
You have included an option that requires an argument without including the argument, so the installer is using the next option as the argument and it is throwing off all of your options/arguments.
Check your options against the --help output. A common mistake is to leave out a "true" or "false" to the boolean options.
Regards,
J
ยทยทยท
> On Mar 28, 2017, at 2:44 AM, Wim Van den Borre wrote:
> Hey Everyone,
> I'm trying to install foreman but when i run the installer i get a bunch of these messages, does anyone know what the problem coulde be?
> foreman-installer
> Parameter foreman-foreman-url invalid: ::foreman::params::foreman_url must match one of (?-mix:^https?:\/\/)
> Parameter foreman-puppetrun invalid: "::foreman::params::puppetrun" is not a valid boolean, "::foreman::params::puppetrun" is not a valid boolean
> Parameter foreman-unattended invalid: "::foreman::params::unattended" is not a valid boolean
> Parameter foreman-authentication invalid: "::foreman::params::authentication" is not a valid boolean
> Parameter foreman-passenger invalid: "::foreman::params::passenger" is not a valid boolean, "::foreman::params::passenger" is not a valid boolean
> Parameter foreman-use-vhost invalid: "::foreman::params::use_vhost" is not a valid boolean
> Parameter foreman-ssl invalid: "::foreman::params::ssl" is not a valid boolean
> Parameter foreman-configure-epel-repo invalid: "::foreman::params::configure_epel_repo" is not a valid boolean
> Parameter foreman-configure-scl-repo invalid: "::foreman::params::configure_scl_repo" is not a valid boolean
> Parameter foreman-selinux invalid: "::foreman::params::selinux" is not a valid boolean
> Parameter foreman-gpgcheck invalid: "::foreman::params::gpgcheck" is not a valid boolean
> Kind regards
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com.
