Hi All,
Is it possible to install foreman with exist ssl certificate?
What are the best practice for it?
Hi Eliran,
I haven't tried that yet but I know that when you run the foreman-installer
command, you can use the following flags:
–foreman-server-ssl-ca
–foreman-server-ssl-cert
–foreman-server-ssl-chain
–foreman-server-ssl-crl
–foreman-server-ssl-key
Good luck,
Royee Tager
On Mon, May 4, 2015 at 9:11 AM, Eliran Shlomo wrote:Hi All,
What are the best practice for it?–
"Foreman users" group.
I tried to install it , the UI is working fine.
but puppet have cert issues
Could not send facts to Foreman: SSL_connect returned=1 errno=0 state=SSLv3
read server certificate B: certificate verify failed
On Monday, May 4, 2015 at 1:43:05 PM UTC+3, Royee Tager wrote: > > Hi Eliran, > > I haven't tried that yet but I know that when you run the > foreman-installer command, you can use the following flags: > > --foreman-server-ssl-ca > --foreman-server-ssl-cert > --foreman-server-ssl-chain > --foreman-server-ssl-crl > --foreman-server-ssl-key > > Good luck, > > Royee Tager > > On Mon, May 4, 2015 at 9:11 AM, Eliran Shlomo > wrote: > >> Hi All, >> Is it possible to install foreman with exist ssl certificate? >> What are the best practice for it? >> >> -- >> You received this message because you are subscribed to the Google Groups >> "Foreman users" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-user...@googlegroups.com . >> To post to this group, send email to forema...@googlegroups.com >> . >> Visit this group at http://groups.google.com/group/foreman-users. >> For more options, visit https://groups.google.com/d/optout. >> > >Hi Eliran,
Check the following parameters in the puppet.conf file:
ca_server
In addition you can try to generate a new certificate (Puppet) instead of
the old one
On Mon, May 4, 2015 at 2:57 PM, Eliran Shlomo wrote:Hi,
but puppet have cert issuesCould not send facts to Foreman: SSL_connect returned=1 errno=0
state=SSLv3 read server certificate B: certificate verify failedOn Monday, May 4, 2015 at 1:43:05 PM UTC+3, Royee Tager wrote:
Hi Eliran,
I haven’t tried that yet but I know that when you run the
foreman-installer command, you can use the following flags:–foreman-server-ssl-ca
–foreman-server-ssl-keyGood luck,
Royee Tager
On Mon, May 4, 2015 at 9:11 AM, Eliran Shlomo eli...@whipclip.com >> wrote:
Hi All,
Groups “Foreman users” group.
an email to foreman-user...@googlegroups.com.
To post to this group, send email to forema...@googlegroups.com.
For more options, visit https://groups.google.com/d/optout.–
