It seemed to me that there should be enough "there" to run the web
interface for Foreman but when I try I get a web screen with the following:
PGError: ERROR: relation "features" does not exist
LINE 4: WHERE a.attrelid = '"features"'::regclass
: SELECT a.attname, format_type(a.atttypid, a.atttypmod),
d.adsrc, a.attnotnull
FROM pg_attribute a LEFT JOIN pg_attrdef d
ON a.attrelid = d.adrelid AND a.attnum = d.adnum
AND a.attnum > 0 AND NOT a.attisdropped
ORDER BY a.attnum
(ActiveRecord::StatementInvalid)
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/postgresql_adapter.rb:1158:in
async_exec' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/postgresql_adapter.rb:1158:in
exec_no_cache'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/postgresql_adapter.rb:664:in
block in exec_query' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract_adapter.rb:280:in
block in log'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications/instrumenter.rb:20:in
instrument' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract_adapter.rb:275:in
log'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/postgresql_adapter.rb:663:in
exec_query' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/postgresql_adapter.rb:1283:in
column_definitions'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/postgresql_adapter.rb:859:in
columns' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/schema_cache.rb:12:in
block in initialize'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/model_schema.rb:228:in
yield' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/model_schema.rb:228:in
default'
columns' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/model_schema.rb:237:in
columns_hash'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/locking/optimistic.rb:129:in
locking_enabled?' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/relation.rb:170:in
exec_queries'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/relation.rb:160:in
block in to_a' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/explain.rb:40:in
logging_query_plan'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/relation.rb:159:in
to_a' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/relation/finder_methods.rb:159:in
all'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/querying.rb:5:in
all' /usr/share/foreman/app/models/feature.rb:7:in
name_map'
/usr/share/foreman/app/models/smart_proxy.rb:39:in <class:SmartProxy>' /usr/share/foreman/app/models/smart_proxy.rb:1:in
<top (required)>'
/opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require' /opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:251:in
block in require' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:236:in
load_dependency'
require' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:359:in
require_or_load'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:502:in
load_missing_constant' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:192:in
block in const_missing'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:190:in
each' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:190:in
const_missing'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:514:in
const_missing'
const_missing'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/inflector/methods.rb:230:in
block in constantize' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/inflector/methods.rb:229:in
each'
constantize' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/inflector/methods.rb:260:in
safe_constantize'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/core_ext/string/inflections.rb:66:in
safe_constantize' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/params_wrapper.rb:152:in
_default_wrap_model'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/params_wrapper.rb:169:in
_set_wrapper_defaults' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/params_wrapper.rb:133:in
inherited'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/railties/routes_helpers.rb:7:in
block (2 levels) in with' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/railties/paths.rb:7:in
/usr/share/foreman/app/controllers/api/v1/smart_proxies_controller.rb:3:in
<module:V1>' /usr/share/foreman/app/controllers/api/v1/smart_proxies_controller.rb:2:in
<module:Api>'
/usr/share/foreman/app/controllers/api/v1/smart_proxies_controller.rb:1:in
<top (required)>' /opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require'
require' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:251:in
block in require'
load_dependency' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:251:in
require'
require_or_load' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:313:in
depend_on'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:225:in
require_dependency' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:439:in
block (2 levels) in eager_load!'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:438:in
each' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:438:in
block in eager_load!'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:436:in
each' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:436:in
eager_load!'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/application/finisher.rb:53:in
block in <module:Finisher>' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:30:in
instance_exec'
run' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:55:in
block in run_initializers'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:54:in
each' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:54:in
run_initializers'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/application.rb:136:in
initialize!' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/railtie/configurable.rb:30:in
method_missing'
/usr/share/foreman/config/environment.rb:5:in <top (required)>' /opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require'
require' config.ru:3:in
block in <main>'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:51:in
instance_eval' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:51:in
initialize'
config.ru:1:in new' config.ru:1:in
<main>'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:105:in
eval' /usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:105:in
preload_app'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:150:in
<module:App>' /usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:29:in
<module:PhusionPassenger>'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:28:in
`<main>'
Application root/usr/share/foremanEnvironment (value of RAILS_ENV,
RACK_ENV, WSGI_ENV and PASSENGER_ENV)productionRuby interpreter command
/usr/bin/ruby193-ruby
User and groups
uid=497(foreman) gid=496(foreman) groups=496(foreman),52(puppet)
Environment variables
MANPATH = /opt/rh/ruby193/root/usr/share/man:
SHELL = /bin/false
TERM = xterm
PYTHONUNBUFFERED = 1
PASSENGER_ENV = production
PASSENGER_DEBUG_DIR = /tmp/passenger.spawn-debug.XXXXS4eM2e
SERVER_PORT = 80
X_SCLS = ruby193
USER = foreman
LD_LIBRARY_PATH = /opt/rh/ruby193/root/usr/lib64:
DOCUMENT_ROOT = /usr/share/foreman/public
REQUEST_URI = /
IN_PASSENGER = 1
RACK_ENV = production
REMOTE_PORT = 48784
PATH = /opt/rh/ruby193/root/usr/bin:/sbin:/usr/sbin:/bin:/usr/bin
WSGI_ENV = production
SERVER_ADMIN = [no address given]
PWD = /usr/share/foreman
LANG = C
REMOTE_ADDR = 127.0.0.1
SERVER_NAME = pocforeman.cip.att.com
HOME = /usr/share/foreman
SHLVL = 5
RAILS_ENV = production
SERVER_SOFTWARE = Apache/2.2.15 (Red Hat)
LOGNAME = foreman
QUERY_STRING =
SERVER_ADDR = 127.0.0.1
SERVER_PROTOCOL = HTTP/1.1
REQUEST_METHOD = HEAD
_ = /opt/rh/ruby193/root/usr/bin/ruby
BUNDLE_GEMFILE = /usr/share/foreman/Gemfile.in
Ulimits
Unknown
System memory usage
total used free shared buffers cached
Mem: 15943 15484 458 0 376 14330
-/+ buffers/cache: 778 15165
Swap: 7999 0 7999
General Ruby interpreter information
RUBY_VERSION = 1.9.3
RUBY_PLATFORM = x86_64-linux
RUBY_ENGINE = ruby
RubyGems version = 1.8.24
Ruby configuration (RbConfig::CONFIG)
DESTDIR =
MAJOR = 1
MINOR = 9
TEENY = 1
PATCHLEVEL = 327
INSTALL = /usr/bin/install -c
EXEEXT =
prefix = /opt/rh/ruby193/root/usr
ruby_install_name = ruby
RUBY_INSTALL_NAME = ruby
RUBY_SO_NAME = ruby
exec = exec
ruby_pc = ruby-1.9.pc
PACKAGE = ruby
BUILTIN_TRANSSRCS = newline.c
USE_VERSIONED_PATHS = NO
USE_RUBYGEMS = YES
MANTYPE = doc
NROFF = /usr/bin/nroff
vendorhdrdir = /opt/rh/ruby193/root/usr/include/vendor_ruby
sitehdrdir = /opt/rh/ruby193/root/usr/include/site_ruby
rubyhdrdir = /opt/rh/ruby193/root/usr/include
UNIVERSAL_INTS =
UNIVERSAL_ARCHNAMES =
configure_args = '–build=x86_64-redhat-linux-gnu'
'–host=x86_64-redhat-linux-gnu' '–target=x86_64-redhat-linux-gnu'
'–program-prefix=' '–prefix=/opt/rh/ruby193/root/usr'
'–exec-prefix=/opt/rh/ruby193/root/usr'
'–bindir=/opt/rh/ruby193/root/usr/bin'
'–sbindir=/opt/rh/ruby193/root/usr/sbin'
'–sysconfdir=/opt/rh/ruby193/root/etc'
'–datadir=/opt/rh/ruby193/root/usr/share'
'–includedir=/opt/rh/ruby193/root/usr/include'
'–libdir=/opt/rh/ruby193/root/usr/lib64'
'–libexecdir=/opt/rh/ruby193/root/usr/libexec'
'–localstatedir=/opt/rh/ruby193/root/usr/var'
'–sharedstatedir=/opt/rh/ruby193/root/usr/com'
'–mandir=/opt/rh/ruby193/root/usr/share/man'
'–infodir=/opt/rh/ruby193/root/usr/share/info'
'–with-rubylibprefix=/opt/rh/ruby193/root/usr/share/ruby'
'–with-archdir=/opt/rh/ruby193/root/usr/lib64/ruby'
'–with-sitedir=/opt/rh/ruby193/root/usr/local/share/ruby/site_ruby'
'–with-sitearchdir=/opt/rh/ruby193/root/usr/local/lib64/ruby/site_ruby'
'–with-vendordir=/opt/rh/ruby193/root/usr/share/ruby/vendor_ruby'
'–with-vendorarchdir=/opt/rh/ruby193/root/usr/lib64/ruby/vendor_ruby'
'–with-rubyhdrdir=/opt/rh/ruby193/root/usr/include'
'–with-rubygemsdir=/opt/rh/ruby193/root/usr/share/rubygems'
'–disable-rpath' '–enable-shared' '–disable-versioned-paths'
'build_alias=x86_64-redhat-linux-gnu'
'host_alias=x86_64-redhat-linux-gnu'
'target_alias=x86_64-redhat-linux-gnu' 'CFLAGS=-O2 -g -pipe -Wall
-Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
–param=ssp-buffer-size=4 -m64 -mtune=generic' 'CXXFLAGS=-O2 -g -pipe
-Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
rubygemsdir = /opt/rh/ruby193/root/usr/share/rubygems
vendordir = /opt/rh/ruby193/root/usr/share/ruby/vendor_ruby
sitedir = /opt/rh/ruby193/root/usr/local/share/ruby/site_ruby
ruby_version = 1.9.1
sitearch = x86_64-linux
arch = x86_64-linux
RI_BASE_NAME = ri
ridir = /opt/rh/ruby193/root/usr/share/ri
rubylibprefix = /opt/rh/ruby193/root/usr/share/ruby
MAKEFILES = Makefile
PLATFORM_DIR =
THREAD_MODEL = pthread
SYMBOL_PREFIX =
EXPORT_PREFIX =
COMMON_HEADERS =
COMMON_MACROS =
COMMON_LIBS =
MAINLIBS =
ENABLE_SHARED = yes
DLDLIBS = -lc
SOLIBS = -lpthread -lrt -ldl -lcrypt -lm
LIBRUBYARG_SHARED = -lruby
LIBRUBYARG_STATIC = -lruby-static
LIBRUBYARG = -lruby
LIBRUBY = libruby.so.1.9.1
LIBRUBY_ALIASES = libruby.so.1.9 libruby.so
LIBRUBY_SO = libruby.so.1.9.1
LIBRUBY_A = libruby-static.a
RUBYW_INSTALL_NAME =
rubyw_install_name =
LIBRUBY_DLDFLAGS = -Wl,-soname,libruby.so.1.9
LIBRUBY_LDSHARED = gcc -shared
warnflags = -Wall -Wextra -Wno-unused-parameter -Wno-parentheses
-Wno-long-long -Wno-missing-field-initializers -Werror=pointer-arith
-Werror=write-strings -Werror=declaration-after-statement
-Werror=implicit-function-declaration
debugflags = -ggdb
optflags = -O3
cxxflags = -O3 -ggdb -Wall -Wextra -Wno-unused-parameter
-Wno-parentheses -Wno-long-long -Wno-missing-field-initializers
-Werror=pointer-arith -Werror=write-strings
cflags = -O3 -ggdb -Wall -Wextra -Wno-unused-parameter
cppflags =
NULLCMD = :
INSTALLDOC = all
CAPITARGET = nodoc
RDOCTARGET = rdoc
EXECUTABLE_EXTS =
ARCHFILE =
LIBRUBY_RELATIVE = no
EXTOUT = .ext
PREP = miniruby
TEST_RUNNABLE = yes
setup = Setup
EXTSTATIC =
STRIP = strip -S -x
TRY_LINK =
LIBPATHENV = LD_LIBRARY_PATH
RPATHFLAG =
LIBPATHFLAG = -L%s
LINK_SO =
LIBEXT = a
DLEXT2 =
DLEXT = so
LDSHAREDXX = g++ -shared
CCDLFLAGS = -fPIC
STATIC =
ARCH_FLAG = -m64
DLDFLAGS =
ALLOCA =
WERRORFLAG = -Werror
CHDIR = cd -P
RMALL = rm -fr
RMDIRS = rmdir --ignore-fail-on-non-empty -p
RMDIR = rmdir --ignore-fail-on-non-empty
CP = cp
RM = rm -f
PKG_CONFIG = pkg-config
DOXYGEN =
DOT =
MAKEDIRS = /bin/mkdir -p
MKDIR_P = /bin/mkdir -p
INSTALL_DATA = /usr/bin/install -c -m 644
INSTALL_SCRIPT = /usr/bin/install -c
INSTALL_PROGRAM = /usr/bin/install -c
SET_MAKE =
LN_S = ln -s
NM = nm
DLLWRAP =
WINDRES =
OBJCOPY = :
OBJDUMP = objdump
ASFLAGS =
AS = as
AR = ar
RANLIB = ranlib
try_header =
COUTFLAG = -o
OUTFLAG = -o
CPPOUTFILE = -o conftest.i
GNU_LD = yes
GCC = yes
EGREP = /bin/grep -E
GREP = /bin/grep
CPP = gcc -E
CXXFLAGS = -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
-fstack-protector --param=ssp-buffer-size=4 -mtune=generic
CXX = g++
OBJEXT = o
CPPFLAGS =
LDFLAGS = -L. -rdynamic -Wl,-export-dynamic
CFLAGS = -O2 -g -pipe -Wall -Wp,-D_FORT
