[ERROR main] foreman-maintain packages is-locked --assumeyes failed! Check the output for error!
[ERROR main] Proxy katello.example.com has failed to load one or more features (DHCP), check /var/log/foreman-proxy/proxy.log for configuration errors
Thanks for you response upon checking the suggested log,
I chanced upon the error line [E]
[E] Disbaling all modules in the group [dhcp_isc, dhcp] due to a failure in one of them: File at /etc/dhcp/dhcpd.conf defined in ‘config’ parameter doesn’t exist or is unreadable
