I am trying to install foreman but keep on getting the same error when
trying to run the installer. I am using the latest version of Centos 7 with
all of the newest updates. I am following the install instructions provided
by foremen. I get the following error when doing any forman-installer
command:
[root@theforeman ~]# foreman-installer --help
/usr/share/ruby/vendor_ruby/puppet/context.rb:54:in lookup': Could not parse for environment production: no 'environments' in {:current_environment=>#<Puppet::Node::Environment:0x000000030dcd40 @name=:"*root*", @modulepath=[], @manifest=:no_manifest, @config_version=nil, @watching=true>, :root_environment=>#<Puppet::Node::Environment:0x000000030dcd40 @name=:"*root*", @modulepath=[], @manifest=:no_manifest, @config_version=nil, @watching=true>} at top of [[0, nil, nil]] (Puppet::Error) from /usr/share/ruby/vendor_ruby/puppet.rb:236:inlookup'
from /usr/share/ruby/vendor_ruby/puppet.rb:264:in future_parser?' from /usr/share/ruby/vendor_ruby/puppet/parser/parser_factory.rb:12:inparser'
from /usr/share/ruby/vendor_ruby/puppet/node/environment.rb:541:in perform_initial_import' from /usr/share/ruby/vendor_ruby/puppet/node/environment.rb:276:inknown_resource_types'
from
/usr/share/ruby/vendor_ruby/puppet/resource/type_collection_helper.rb:5:in known_resource_types' from /usr/share/ruby/vendor_ruby/puppet/parser/parser_support.rb:120:inimport'
from
/usr/share/gems/gems/kafo_parsers-0.0.4/lib/kafo_parsers/puppet_module_parser.rb:38:in initialize' from /usr/share/gems/gems/kafo_parsers-0.0.4/lib/kafo_parsers/puppet_module_parser.rb:16:innew'
from
/usr/share/gems/gems/kafo_parsers-0.0.4/lib/kafo_parsers/puppet_module_parser.rb:16:in parse' from /usr/share/gems/gems/kafo-0.6.5/lib/kafo/puppet_module.rb:44:inparse'
from
/usr/share/gems/gems/kafo-0.6.5/lib/kafo/configuration.rb:84:in block in modules' from /usr/share/gems/gems/kafo-0.6.5/lib/kafo/configuration.rb:84:inmap'
from
/usr/share/gems/gems/kafo-0.6.5/lib/kafo/configuration.rb:84:in modules' from /usr/share/gems/gems/kafo-0.6.5/lib/kafo/kafo_configure.rb:170:inmodules'
from
/usr/share/gems/gems/kafo-0.6.5/lib/kafo/kafo_configure.rb:152:in params' from /usr/share/gems/gems/kafo-0.6.5/lib/kafo/kafo_configure.rb:185:inset_parameters'
from
/usr/share/gems/gems/kafo-0.6.5/lib/kafo/kafo_configure.rb:66:in initialize' from /usr/share/gems/gems/clamp-0.6.2/lib/clamp/command.rb:126:innew'
from /usr/share/gems/gems/clamp-0.6.2/lib/clamp/command.rb:126:in run' from /usr/share/gems/gems/kafo-0.6.5/lib/kafo/kafo_configure.rb:116:inrun'
from /usr/sbin/foreman-installer:18:in `<main>'
The release today of Puppet 3.7.5 breaks the installer. We recommend
downgrading puppet and re-running.
command:
/usr/share/ruby/vendor_ruby/puppet/context.rb:54:in lookup': Could not parse for environment production: no 'environments' in {:current_environment=>#<Puppet::Node::Environment:0x000000030dcd40 @name=:"*root*", @modulepath=[], @manifest=:no_manifest, @config_version=nil, @watching=true>, :root_environment=>#<Puppet::Node::Environment:0x000000030dcd40 @name=:"*root*", @modulepath=[], @manifest=:no_manifest, @config_version=nil, @watching=true>} at top of [[0, nil, nil]] (Puppet::Error) from /usr/share/ruby/vendor_ruby/puppet.rb:236:inlookup’
from /usr/share/ruby/vendor_ruby/puppet.rb:264:in future_parser?' from /usr/share/ruby/vendor_ruby/puppet/parser/parser_factory.rb:12:inparser’
from /usr/share/ruby/vendor_ruby/puppet/node/environment.rb:541:in perform_initial_import' from /usr/share/ruby/vendor_ruby/puppet/node/environment.rb:276:inknown_resource_types’
from
/usr/share/ruby/vendor_ruby/puppet/resource/type_collection_helper.rb:5:in known_resource_types' from /usr/share/ruby/vendor_ruby/puppet/parser/parser_support.rb:120:inimport’
from
/usr/share/gems/gems/kafo_parsers-0.0.4/lib/kafo_parsers/puppet_module_parser.rb:38:in initialize' from /usr/share/gems/gems/kafo_parsers-0.0.4/lib/kafo_parsers/puppet_module_parser.rb:16:innew’
from
/usr/share/gems/gems/kafo_parsers-0.0.4/lib/kafo_parsers/puppet_module_parser.rb:16:in parse' from /usr/share/gems/gems/kafo-0.6.5/lib/kafo/puppet_module.rb:44:inparse’
from
/usr/share/gems/gems/kafo-0.6.5/lib/kafo/configuration.rb:84:in block in modules' from /usr/share/gems/gems/kafo-0.6.5/lib/kafo/configuration.rb:84:inmap’
from
/usr/share/gems/gems/kafo-0.6.5/lib/kafo/configuration.rb:84:in modules' from /usr/share/gems/gems/kafo-0.6.5/lib/kafo/kafo_configure.rb:170:inmodules’
from
/usr/share/gems/gems/kafo-0.6.5/lib/kafo/kafo_configure.rb:152:in params' from /usr/share/gems/gems/kafo-0.6.5/lib/kafo/kafo_configure.rb:185:inset_parameters’
from
/usr/share/gems/gems/kafo-0.6.5/lib/kafo/kafo_configure.rb:66:in initialize' from /usr/share/gems/gems/clamp-0.6.2/lib/clamp/command.rb:126:innew’
from /usr/share/gems/gems/clamp-0.6.2/lib/clamp/command.rb:126:in run' from /usr/share/gems/gems/kafo-0.6.5/lib/kafo/kafo_configure.rb:116:inrun’
from /usr/sbin/foreman-installer:18:in `’
