I’m opening a new topic in case it may help somebody new to Foreman and Puppet like I was (and still am, though less and less ;-)).
After more detailed researched, and after my original post (Foreman in multi interface setup experience digest) here’s what I understood (correct me if I’m wrong) about the foreman layout (as installed on CentOS following the manual) :
There are 3 main components :
- foreman-installer
- foreman
- foreman-proxy
each having resources in /etc/
and /usr/share/
directories
/etc/foreman-installer and /usr/share/foreman-installer
/etc/foreman and /usr/share/foreman
/etc/foreman-proxy and /usr/share/foreman-proxy
I. foreman-installer
/sbin/foreman-installer
: ruby, kafofy generated, exec script
Configuration(s)
/etc/foreman-installer/
: config dir -
etc/foreman-installer/custom-hiera.yaml
: custom hiera data-source -
/etc/foreman-installer/scenario.d/
: kafo scenarii (only one named Foreman in our case) -
/etc/foreman-installer/scenario.d/foreman.yaml
: foreman scenario config file -
/etc/foreman-installer/scenario.d/last_scenario.yaml -> foreman.yaml
: last scenario (foreman in our case since there’s only one)
In config file we find, among other entries :
:mapping: {}
:answer_file: /etc/foreman-installer/scenarios.d/foreman-answers.yaml
:installer_dir: /usr/share/foreman-installer
:module_dirs: /usr/share/foreman-installer/modules
:hiera_config: /usr/share/foreman-installer/config/foreman-hiera.conf
:parser_cache_path: /usr/share/foreman-installer/parser_cache/foreman.yaml
:order:
- foreman
- foreman_proxy
- puppet
So we can see where are located the different components of the foreman-installer. For instance, the answer file for this single scenario is
Puppet modules
/usr/share/foreman-installer/modules/
: modules used by foreman-installer and considered for kafo generated CLI options
Manifests
/usr/share/foreman-installer/modules/<module>/manifests/
: Puppet code of <module> -
/usr/share/foreman-installer/modules/<module>/manifests/init.pp
: class <module> (<type> $<param> = $<module>::params::<param>) inherits <module>::params {…} : main class of <module> which inherits params to use its parameters -
/usr/share/foreman-installer/modules/<module>/manifests/params.pp
: class <module>::params holding parameters used in <module> class defined ininit.pp
. Also where kafo gets it’s default parameters values. -
/usr/share/foreman-installer/modules/<module>/manifests/<other class>.pp
: class or defined type <module>::<otherclass> (…) {…} : other classes or defined types defined in the module which may be instanciated
Templates
/usr/share/foreman-installer/modules/<module>/templates/
: templates dir of <module> module
(Ruby) Types
/usr/share/foreman-installer/modules/<module>/types/
: Ruby types used by <module>
Hiera conf
Puppet automatically looks for parameters in Hiera, so this is preferred to the init.pp / params.pp Puppet pattern.
In hiera data source files, entries look like that :
<module>::<param>: <value>
: global hiera config file (might be one per module as well)
Interesting values, among others, are :
:hierarchy:
- custom
- kafo_answers
- security
- tuning
- "%{::osfamily}"
and
:datadir: /usr/share/foreman-installer/config/foreman.hiera
The custom.yaml
data source, which is a symlink to /etc/foreman-installer/custom-hiera.yaml
allows to pass additionnal (not defined in params.pp
file for instance) parameters (an additional dhcp subnet for instance)
Puppet parser cache
: Puppet parser cache (checked against manifests timestamps)
Migrations
I’m not quite sure how this works (I haven’t checked it out yet)
II. Foreman-proxy (Smart Proxies)
/etc/foreman-proxy/
: Smart Proxies configuration dir -
/etc/foreman-proxy/settings.yml
: general Smart Proxies settings -
/etc/foreman-proxy/settings.d/*.yml : per proxy settings
Those files are initially created by the foreman_proxy Puppet module (via the foreman-installer) :
/usr/share/foreman-installer/modules/foreman_proxy
As a matter of fact, in this module, there are Puppet defined types and templates matching those files
UI vs Puppet (foreman-installer)
What’s done in the UI has nothing to do with what’s done with the installer. In particular, creating a subnet via foreman-installer options (i.e. via puppet modules) - possibly augmented with additionnal subnets listed in custom-hiera.yml
data sources, has nothing to do with what’s done in the subnet tab in the UI
For instance, here’s how the Puppet code typically flows :
foreman_proxy
(init.pp
) class inheritsforeman_proxy::params
(params.pp
) class and uses its parameters -
foreman_proxy::service
(service.pp
) class requiresforeman_proxy::config
(config.pp) class -
(config.pp
) class conditionnally includesforeman_proxy::proxydhcp
class -
(proxydhcp.pp
) instanciates classes (dhcp
,pool
) of the general::dhcp
module -
class instanciatesforeman_proxy::settings::settings_file
defined type -
defined type
expands templates of foreman-proxy settings files (i.e.settings.yml
andsettings.d/*.yml
So regarding dhcp, there isn’t 2 modules as the layout might let one think but a general dhcp module and its particular use in the foreman-installer context :
/usr/share/foreman-installer/modules/dhcp/
: module
/usr/share/foreman-installer/modules/foreman_proxy/manifests/proxydhcp.pp
: specific use of the module
Questions :
At this point, I’m not sure if actions done in the UI car write into setting.yml and settings.d/*.yml file
kafo seems to provide a reset parameter option to restore to the (not considering answer file) default value but I don’t know if all defaults can be restored
Thanks
TH.
