We upgraded foreman to 1.11 anf katello to 3.0-rc1 and we get an error when
doing the db::migrate:
== 20150930183738 MigrateContentHosts: migrating
rake aborted!
StandardError: An error has occurred, this and all later migrations
canceled:
PG::Error: ERROR: update or delete on table “katello_systems” violates
foreign key constraint “system_activation_keys_system_id_fk” on table
"katello_system_activation_keys"
DETAIL: Key (id)=(673) is still referenced from table
"katello_system_activation_keys".
: DELETE FROM “katello_systems” WHERE “katello_systems”.“id” =
673/opt/rh/rh-ror41/root/usr/share/gems/gems/activerecord-4.1.5/lib/active_record/connection_adapters/postgresql_adapter.rb:822:in
exec' /opt/rh/rh-ror41/root/usr/share/gems/gems/activerecord-4.1.5/lib/active_record/connection_adapters/postgresql_adapter.rb:822:in
block in exec_no_cache’
/opt/rh/rh-ror41/root/usr/share/gems/gems/activerecord-4.1.5/lib/active_record/connection_adapters/abstract_adapter.rb:373:in
block in log' /opt/rh/rh-ror41/root/usr/share/gems/gems/activesupport-4.1.5/lib/active_support/notifications/instrumenter.rb:20:in
instrument’
Any help on how we can get past this?
Thank you,
Cristian Falcas
Cristian,
Can you file an issue here with that traceback and the version and we can
look into it more?
http://projects.theforeman.org/projects/katello/issues/new
John Mitsch
Red Hat Engineering
(860)-967-7285
irc: jomitsch
when doing the db::migrate:
rake aborted!
canceled:
instrument’
Thank you,
Cristian Falcas
"Foreman users" group.
I opened Bug #14551: after foreman and katello upgrade db:migrate fails - Katello - Foreman
Thank you
On Fri, Apr 8, 2016 at 4:26 PM, John Mitsch wrote:
Cristian,
look into it more?
Foreman
John Mitsch
Red Hat Engineering
(860)-967-7285
irc: jomitsch
On Fri, Apr 8, 2016 at 8:05 AM, Cristian Falcas cristi.falcas@gmail.com > wrote:
rake aborted!
canceled:
instrument’
Thank you,
Cristian Falcas
