What’s the best way to set more complicated smart class parameter in Foreman.
I’m using the elasticsearch module and I want to use something like the following -
class { 'filebeat':
outputs => {
'logstash' => {
'hosts' => [
'localhost:5044',
'anotherserver:5044'
'loadbalance' => true,
now for setting a simple string I find it easy eg just set “logstash” but is it better to set the above code as array, yaml, json?
Use foreman to set filebeat.yml to use logstash on all RHEL hosts.
Puppet Module imported into Foreman
