foreman-nightly-rpm-pipeline 600 failed
Foreman RPM nightly pipeline failed:
https://ci.theforeman.org/job/foreman-nightly-rpm-pipeline/600/
foreman-nightly-centos8-test (failed)
foreman-nightly-centos7-test (failed)
foreman-nightly-centos7-upgrade-test (failed)
[ INFO 2020-06-06T22:11:04 verbose]  Class[Foreman::Database]: Scheduling refresh of Service[dynflow-sidekiq@worker]
[ INFO 2020-06-06T22:11:04 verbose]  Class[Apache::Service]: Scheduling refresh of Service[httpd]
[ERROR 2020-06-06T22:11:04 verbose]  Systemd start for httpd failed!
[ERROR 2020-06-06T22:11:04 verbose] journalctl log for httpd:
[ERROR 2020-06-06T22:11:04 verbose] -- Logs begin at Sat 2020-06-06 21:59:12 UTC, end at Sat 2020-06-06 22:11:04 UTC. --
[ERROR 2020-06-06T22:11:04 verbose] Jun 06 22:11:04 pipeline-foreman-server-nightly-centos8.n14.example.com systemd[1]: Starting The Apache HTTP Server...
[ERROR 2020-06-06T22:11:04 verbose] Jun 06 22:11:04 pipeline-foreman-server-nightly-centos8.n14.example.com httpd[9398]: AH00526: Syntax error on line 58 of /etc/httpd/conf.d/05-foreman-ssl.conf:
[ERROR 2020-06-06T22:11:04 verbose] Jun 06 22:11:04 pipeline-foreman-server-nightly-centos8.n14.example.com httpd[9398]: SSLCertificateFile: file '/etc/puppetlabs/puppet/ssl/certs/pipeline-foreman-server-nightly-centos8.n14.example.com.pem' does not exist or is empty
[ERROR 2020-06-06T22:11:04 verbose] Jun 06 22:11:04 pipeline-foreman-server-nightly-centos8.n14.example.com systemd[1]: httpd.service: Main process exited, code=exited, status=1/FAILURE
[ERROR 2020-06-06T22:11:04 verbose] Jun 06 22:11:04 pipeline-foreman-server-nightly-centos8.n14.example.com systemd[1]: httpd.service: Failed with result 'exit-code'.
[ERROR 2020-06-06T22:11:04 verbose] Jun 06 22:11:04 pipeline-foreman-server-nightly-centos8.n14.example.com systemd[1]: Failed to start The Apache HTTP Server.
