TASK [forklift_versions : get forklift versions] *******************************
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: ModuleNotFoundError: No module named 'yaml'
fatal: [pipeline-foreman-server-nightly-centos8]: FAILED! => changed=false
module_stderr: |-
Shared connection to 192.168.121.127 closed.
module_stdout: |-
File "/tmp/ansible/ansible-tmp-1594850271.88-9572-237276624415120/AnsiballZ_forklift_versions.py", line 102, in <module>
_ansiballz_main()
File "/tmp/ansible/ansible-tmp-1594850271.88-9572-237276624415120/AnsiballZ_forklift_versions.py", line 94, in _ansiballz_main
invoke_module(zipped_mod, temp_path, ANSIBALLZ_PARAMS)
File "/tmp/ansible/ansible-tmp-1594850271.88-9572-237276624415120/AnsiballZ_forklift_versions.py", line 40, in invoke_module
runpy.run_module(mod_name='ansible.modules.forklift_versions', init_globals=None, run_name='__main__', alter_sys=True)
File "/usr/lib64/python3.6/runpy.py", line 205, in run_module
return _run_module_code(code, init_globals, run_name, mod_spec)
File "/usr/lib64/python3.6/runpy.py", line 96, in _run_module_code
mod_name, mod_spec, pkg_name, script_name)
File "/usr/lib64/python3.6/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/tmp/ansible_forklift_versions_payload_ca1janu5/ansible_forklift_versions_payload.zip/ansible/modules/forklift_versions.py", line 33, in <module>
msg: |-
MODULE FAILURE
See stdout/stderr for the exact error
rc: 1
