Foreman nightly pipeline failed:
https://ci.theforeman.org/job/foreman-nightly-rpm-pipeline/707/
Proxy seems to be failing on HTTPBoot feature?
[ INFO 2019-03-09T22:09:42 verbose] Class[Foreman_proxy::Register]: Scheduling refresh of Foreman_smartproxy[pipeline-foreman-nightly-centos7.n34.example.com]
[ERROR 2019-03-09T22:10:05 verbose] Proxy pipeline-foreman-nightly-centos7.n34.example.com has failed to load one or more features (HTTPBoot), check /var/log/foreman-proxy/proxy.log for configuration errors
[ERROR 2019-03-09T22:10:05 verbose] /usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:70:in `validate_features!'
[ERROR 2019-03-09T22:10:05 verbose] /usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:24:in `create'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property/ensure.rb:16:in `block in defaultvalues'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:491:in `set'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property.rb:568:in `sync'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:238:in `sync'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:134:in `sync_if_needed'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:80:in `perform_changes'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:21:in `evaluate'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:259:in `apply'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:279:in `eval_resource'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:183:in `call'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:183:in `block (2 levels) in evaluate'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:519:in `block in thinmark'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/2.4.0/benchmark.rb:308:in `realtime'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:518:in `thinmark'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:183:in `block in evaluate'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:121:in `traverse'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:173:in `evaluate'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:239:in `block (2 levels) in apply'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:238:in `block in apply'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:156:in `with_destination'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:146:in `as_logging_destination'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:237:in `apply'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:186:in `block (2 levels) in apply_catalog'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:185:in `block in apply_catalog'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:232:in `block in benchmark'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:231:in `benchmark'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:184:in `apply_catalog'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:369:in `run_internal'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:237:in `block in run'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:65:in `override'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:260:in `override'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:211:in `run'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:355:in `apply_catalog'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:280:in `block (2 levels) in main'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:280:in `block in main'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:233:in `main'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:174:in `run_command'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `block in run'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:667:in `exit_on_fail'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `run'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:135:in `run'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:73:in `execute'
[ERROR 2019-03-09T22:10:05 verbose] /opt/puppetlabs/puppet/bin/puppet:5:in `<main>'
[ERROR 2019-03-09T22:10:05 verbose] /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[pipeline-foreman-nightly-centos7.n34.example.com]/ensure: change from 'absent' to 'present' failed: Proxy pipeline-foreman-nightly-centos7.n34.example.com has failed to load one or more features (HTTPBoot), check /var/log/foreman-proxy/proxy.log for configuration errors
[ERROR 2019-03-09T22:10:06 verbose] /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[pipeline-foreman-nightly-centos7.n34.example.com]: Failed to call refresh: Proxy pipeline-foreman-nightly-centos7.n34.example.com has failed to load one or more features (HTTPBoot), check /var/log/foreman-proxy/proxy.log for configuration errors
[ERROR 2019-03-09T22:10:06 verbose] /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[pipeline-foreman-nightly-centos7.n34.example.com]: Proxy pipeline-foreman-nightly-centos7.n34.example.com has failed to load one or more features (HTTPBoot), check /var/log/foreman-proxy/proxy.log for configuration errors
[ERROR 2019-03-09T22:10:06 verbose] /usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:70:in `validate_features!'
[ERROR 2019-03-09T22:10:06 verbose] /usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:59:in `refresh_features!'
[ERROR 2019-03-09T22:10:06 verbose] /usr/share/foreman-installer/modules/foreman/lib/puppet/type/foreman_smartproxy.rb:73:in `refresh'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:147:in `process_callback'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:34:in `block in process_events'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:119:in `block in queued_events'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:118:in `each'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:118:in `queued_events'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:33:in `process_events'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:280:in `eval_resource'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:183:in `call'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:183:in `block (2 levels) in evaluate'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:519:in `block in thinmark'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/2.4.0/benchmark.rb:308:in `realtime'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:518:in `thinmark'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:183:in `block in evaluate'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:121:in `traverse'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:173:in `evaluate'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:239:in `block (2 levels) in apply'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:238:in `block in apply'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:156:in `with_destination'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:146:in `as_logging_destination'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:237:in `apply'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:186:in `block (2 levels) in apply_catalog'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:185:in `block in apply_catalog'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:232:in `block in benchmark'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:231:in `benchmark'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:184:in `apply_catalog'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:369:in `run_internal'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:237:in `block in run'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:65:in `override'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:260:in `override'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:211:in `run'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:355:in `apply_catalog'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:280:in `block (2 levels) in main'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:280:in `block in main'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:233:in `main'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:174:in `run_command'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `block in run'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:667:in `exit_on_fail'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `run'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:135:in `run'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:73:in `execute'
[ERROR 2019-03-09T22:10:06 verbose] /opt/puppetlabs/puppet/bin/puppet:5:in `<main>'
[ INFO 2019-03-09T22:10:06 verbose] Class[Foreman_proxy]: Unscheduling all events on Class[Foreman_proxy]
[ WARN 2019-03-09T22:10:06 verbose] /Stage[main]/Puppet::Agent::Service::Daemon/Service[puppet]: Dependency Foreman_smartproxy[pipeline-foreman-nightly-centos7.n34.example.com] has failures: true
