jenkins
February 27, 2023, 3:31pm
#1
foreman-packaging-rpm-nightly-release failed for rubygem-foreman_puppet,rubygem-foreman_virt_who_configure,rubygem-hammer_cli_foreman_remote_execution,rubygem-smart_proxy_ansible
https://ci.theforeman.org/job/foreman-packaging-rpm-nightly-release/1906/
Foreman RPM packaging release job failed: foreman-packaging-rpm-nightly-release #1906 [Jenkins]
ekohl
February 27, 2023, 4:01pm
#2
This fails because it tries to tag rubygem-foreman_virt_who_configure-0.5.13-1.fm3_7.el8
, because it exists. However, it failed so it can’t. I’ve opened an issue:
opened 04:01PM - 27 Feb 23 UTC
From https://ci.theforeman.org/blue/organizations/jenkins/foreman-packaging-rpm-… nightly-release/detail/foreman-packaging-rpm-nightly-release/1906/pipeline
[2023-02-27T15:31:30.385Z] + python -m obal release rubygem-foreman_puppet rubygem-foreman_virt_who_configure rubygem-hammer_cli_foreman_remote_execution rubygem-smart_proxy_ansible --skip-koji-whitelist-check
[2023-02-27T15:31:31.592Z]
[2023-02-27T15:31:31.592Z] PLAY [packages] ****************************************************************
[2023-02-27T15:31:31.994Z]
[2023-02-27T15:31:31.994Z] TASK [setup_workspace : Define tmp directory] **********************************
[2023-02-27T15:31:31.994Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:32.497Z]
[2023-02-27T15:31:32.497Z] TASK [setup_workspace : Ensure .tmp directory] *********************************
[2023-02-27T15:31:32.497Z] changed: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:33.102Z]
[2023-02-27T15:31:33.102Z] TASK [git_annex_setup : call git annex init] ***********************************
[2023-02-27T15:31:33.102Z] changed: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:33.607Z]
[2023-02-27T15:31:33.607Z] TASK [ensure_package : check for package dir] **********************************
[2023-02-27T15:31:33.607Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:34.010Z]
[2023-02-27T15:31:34.010Z] TASK [spec_file : Set spec file path] ******************************************
[2023-02-27T15:31:34.010Z] TASK [spec_file : get spec file] ***********************************************
[2023-02-27T15:31:34.010Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:34.111Z]
[2023-02-27T15:31:34.111Z] TASK [setup_sources : Set package_dir] *****************************************
[2023-02-27T15:31:34.111Z] included: /home/jenkins/workspace/foreman-packaging-rpm-nightly-release/obal/obal/data/roles/setup_sources/tasks/specfile.yml for rubygem-foreman_virt_who_configure
[2023-02-27T15:31:34.111Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:34.523Z]
[2023-02-27T15:31:34.523Z] TASK [setup_sources : Extract Sources from spec] *******************************
[2023-02-27T15:31:34.523Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:34.623Z]
[2023-02-27T15:31:34.623Z] TASK [setup_sources : Set source values] ***************************************
[2023-02-27T15:31:34.623Z] included: /home/jenkins/workspace/foreman-packaging-rpm-nightly-release/obal/obal/data/roles/setup_sources/tasks/annex.yml for rubygem-foreman_virt_who_configure
[2023-02-27T15:31:34.623Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:34.724Z]
[2023-02-27T15:31:34.724Z] TASK [setup_sources : Set source path] *****************************************
[2023-02-27T15:31:34.724Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:34.925Z]
[2023-02-27T15:31:34.925Z] TASK [setup_sources : Source exists] *******************************************
[2023-02-27T15:31:34.925Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:35.528Z]
[2023-02-27T15:31:35.528Z] cmd: git annex whereis /home/jenkins/workspace/foreman-packaging-rpm-nightly-release/packages/katello//rubygem-foreman_virt_who_configure/foreman_virt_who_configure-0.5.13.gem 2>/dev/null | grep -q "web:"
[2023-02-27T15:31:35.528Z] delta: '0:00:00.383340'
[2023-02-27T15:31:35.528Z] end: '2023-02-27 15:31:35.486479'
[2023-02-27T15:31:35.528Z] msg: non-zero return code
[2023-02-27T15:31:35.528Z] rc: 1
[2023-02-27T15:31:35.528Z] start: '2023-02-27 15:31:35.103139'
[2023-02-27T15:31:35.528Z] stderr: ''
[2023-02-27T15:31:35.528Z] stderr_lines: <omitted>
[2023-02-27T15:31:35.528Z] stdout: ''
[2023-02-27T15:31:35.528Z] stdout_lines: <omitted>
[2023-02-27T15:31:35.528Z] ...ignoring
[2023-02-27T15:31:35.528Z] TASK [setup_sources : Search annex for web link] *******************************
[2023-02-27T15:31:35.528Z] fatal: [rubygem-foreman_virt_who_configure]: FAILED! => changed=false
[2023-02-27T15:31:35.830Z]
[2023-02-27T15:31:35.830Z] TASK [setup_sources : Remove source] *******************************************
[2023-02-27T15:31:35.830Z] changed: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:36.638Z]
[2023-02-27T15:31:36.638Z] TASK [setup_sources : Add url to annex for source] *****************************
[2023-02-27T15:31:36.638Z] changed: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:36.940Z]
[2023-02-27T15:31:36.940Z] TASK [setup_sources : Ensure no actual change happened] ************************
[2023-02-27T15:31:36.940Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:37.041Z] included: /home/jenkins/workspace/foreman-packaging-rpm-nightly-release/obal/obal/data/roles/build_package/tasks/koji.yml for rubygem-foreman_virt_who_configure
[2023-02-27T15:31:37.142Z] included: /home/jenkins/workspace/foreman-packaging-rpm-nightly-release/obal/obal/data/roles/build_package/tasks/koji_build.yml for rubygem-foreman_virt_who_configure
[2023-02-27T15:31:37.544Z]
[2023-02-27T15:31:37.544Z] TASK [build_package : Package name] ********************************************
[2023-02-27T15:31:37.544Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:39.559Z]
[2023-02-27T15:31:39.559Z] TASK [build_package : Check build status] **************************************
[2023-02-27T15:31:39.559Z] ok: [rubygem-foreman_virt_who_configure]
[2023-02-27T15:31:39.660Z]
[2023-02-27T15:31:39.660Z] changed: false
[2023-02-27T15:31:39.660Z] exists: true
[2023-02-27T15:31:39.660Z] exists_for_tag: false
[2023-02-27T15:31:39.660Z] failed: false
[2023-02-27T15:31:39.660Z] tagged_version: rubygem-foreman_virt_who_configure-0.5.12-1.fm3_6.el8
[2023-02-27T15:31:39.660Z] msg:
[2023-02-27T15:31:39.660Z] TASK [build_package : debug] ***************************************************
[2023-02-27T15:31:39.660Z] ok: [rubygem-foreman_virt_who_configure] =>
[2023-02-27T15:31:40.966Z]
[2023-02-27T15:31:40.966Z] - katello-nightly-el8
[2023-02-27T15:31:40.966Z] - koji
[2023-02-27T15:31:40.966Z] - rubygem-foreman_virt_who_configure-0.5.13-1.fm3_7.el8
[2023-02-27T15:31:40.966Z] - tag-build
[2023-02-27T15:31:40.966Z] command:
[2023-02-27T15:31:40.966Z] msg: ''
[2023-02-27T15:31:40.966Z] TASK [build_package : Tag package build into Koji tag] *************************
[2023-02-27T15:31:40.966Z] fatal: [rubygem-foreman_virt_who_configure]: FAILED! => changed=false
The problem is that [`rubygem-foreman_virt_who_configure-0.5.13-1.fm3_7.el8`](http://koji.katello.org/koji/buildinfo?buildID=74234) exists but failed so it's not a valid build to tag in.
ekohl
February 28, 2023, 1:01pm
#3
system
Closed
March 7, 2023, 1:02pm
#4
