jenkins
#1
ekohl
#2
Looks like openscap has an issue. Perhaps it was updated in stream and our gem needs an update.
[2022-02-15T18:23:55.973Z] TASK [update_os_packages : RedHat | Update packages] ***************************
[2022-02-15T18:23:55.973Z] e[0;31mfatal: [pipe-up-plugins-3.2-centos8-stream]: FAILED! => changed=false e[0m
[2022-02-15T18:23:55.973Z] e[0;31m failures: []e[0m
[2022-02-15T18:23:55.973Z] e[0;31m msg: |-e[0m
[2022-02-15T18:23:55.973Z] e[0;31m Depsolve Error occured:e[0m
[2022-02-15T18:23:55.973Z] e[0;31m Problem: package rubygem-openscap-0.4.9-6.el8.noarch requires openscap < 1.3.6, but none of the providers can be installede[0m
[2022-02-15T18:23:55.973Z] e[0;31m - openscap-1.3.5-10.el8.i686 has inferior architecturee[0m
[2022-02-15T18:23:55.973Z] e[0;31m - openscap-1.3.4-5.el8.i686 has inferior architecturee[0m
[2022-02-15T18:23:55.973Z] e[0;31m - openscap-1.3.5-2.el8.i686 has inferior architecturee[0m
[2022-02-15T18:23:55.973Z] e[0;31m - openscap-1.3.5-4.el8.i686 has inferior architecturee[0m
[2022-02-15T18:23:55.973Z] e[0;31m - openscap-1.3.5-5.el8.i686 has inferior architecturee[0m
[2022-02-15T18:23:55.973Z] e[0;31m - openscap-1.3.5-6.el8.i686 has inferior architecturee[0m
[2022-02-15T18:23:55.973Z] e[0;31m - openscap-1.3.5-9.el8.i686 has inferior architecturee[0m
[2022-02-15T18:23:55.973Z] e[0;31m - cannot install both openscap-1.3.6-3.el8.x86_64 and openscap-1.3.5-10.el8.x86_64e[0m
[2022-02-15T18:23:55.973Z] e[0;31m - cannot install both openscap-1.3.6-3.el8.x86_64 and openscap-1.3.4-5.el8.x86_64e[0m
[2022-02-15T18:23:55.973Z] e[0;31m - cannot install both openscap-1.3.6-3.el8.x86_64 and openscap-1.3.5-2.el8.x86_64e[0m
[2022-02-15T18:23:55.973Z] e[0;31m - cannot install both openscap-1.3.6-3.el8.x86_64 and openscap-1.3.5-4.el8.x86_64e[0m
[2022-02-15T18:23:55.973Z] e[0;31m - cannot install both openscap-1.3.6-3.el8.x86_64 and openscap-1.3.5-5.el8.x86_64e[0m
[2022-02-15T18:23:55.973Z] e[0;31m - cannot install both openscap-1.3.6-3.el8.x86_64 and openscap-1.3.5-6.el8.x86_64e[0m
[2022-02-15T18:23:55.973Z] e[0;31m - cannot install both openscap-1.3.6-3.el8.x86_64 and openscap-1.3.5-9.el8.x86_64e[0m
[2022-02-15T18:23:55.973Z] e[0;31m - cannot install the best update candidate for package rubygem-openscap-0.4.9-6.el8.noarche[0m
[2022-02-15T18:23:55.973Z] e[0;31m - cannot install the best update candidate for package openscap-1.3.5-10.el8.x86_64e[0m
system
Closed
#3
