The plugin GitHub - theforeman/foreman_fog_proxmox: Foreman plugin to add Proxmox compute resource based on fog-proxmox gem requires interfaces to be net[n]
where n is integer >=0.
Once I install a new VM using PXE the interface-name is set to ens18
during the installation. The installation succeeds but once puppet agent runs on the machine, the interface-name is renamed to ens18
which causes the VM to be unsaveable, as the plugin requires the name to be net[n]
Now I just wonder, how to proceed:
- Waiting for proxmox-plugin to no longer require the interface-name to be
net[n]
, which I am not sure is happening at all - Set the interface-name to the required schema and prevent the installer to set the name
ens18
For option 2 I am not sure how I can archive that. The Debian-installer is being loaded by PXE and I did not figure out how to change the naming-scheme of interfaces here.
- Debian 10 (Foreman and deployed VM)
