Foreman prevent catalog from CLI, classes could not be deleted
I installed foreman separately from a master, after I imported class from master, I found the agents could be cataloged from master with puppet agent —test any more, and there was even no error messages from command lines, it seems the only way to make it work is to apply classes to host groups in foreman. And when I tried to delete classes from foreman, I got :
Warning!
ERROR: update or delete on table "puppetclasses" violates foreign key constraint "environment_classes_puppetclass_id_fk" on table "environment_classes" DETAIL: Key (id)=(5) is still referenced from table "environment_classes”.
So how could I enable the catalog from both foreman and command-line, and how could delete classes from foreman? Thanks in advance.
Regards
He Junfeng
> Hi,
Sorry, I don't understand what's happening here. Are you saying that
the Puppet agent runs and makes no changes without error? Can you
provide logs?
Does your separate Puppet master have an ENC set up?
http://theforeman.org/manuals/1.5/index.html#3.5.5FactsandtheENC
> foreman, I got :
> Warning!
This is a known bug. If you want to remove the class from Foreman, do
so via the import - delete it from the Puppet master and then import the
change.
··· On 06/08/14 05:53, Junfeng He wrote:
Dominic Cleal
Red Hat Engineering
Yes, I did. Below is the log,
Info: Retrieving pluginfacts
Info: Loading facts in /var/lib/puppet/lib/facter/facter_dot_d.rb
Info: Loading facts in /var/lib/puppet/lib/facter/puppet_vardir.rb
Info: Loading facts in /var/lib/puppet/lib/facter/pe_version.rb
Info: Loading facts in /var/lib/puppet/lib/facter/root_home.rb
Info: Caching catalog for ca01.test.com
Info: Applying configuration version '1407309963'
Notice: Finished catalog run in 0.03 seconds
Now the classes can only be distributed from foreman.
puppet agent --test any more, and there was even no error messages from
Sorry, I don’t understand what’s happening here. Are you saying that
provide logs?
Foreman :: Manual
foreman, I got :
    Warning!
ERROR: update or delete on table “puppetclasses” violates foreign key
constraint “environment_classes_puppetclass_id_fk” on table
table “environment_classes”.
change.
Dominic Cleal
Red Hat Engineering
"Foreman users" group.
Try running the ENC and see if it returns any output for your host:
/etc/puppet/node.rb ca01.test.com
You need to narrow down whether the ENC (and Foreman, which can be
viewed via the YAML button on a host's page) are returning no classes
for your host, or if the Puppet master isn't configured to execute
node.rb and so it's returning nothing.
··· -- Dominic Cleal Red Hat Engineering
Info: Applying configuration version '1407309963’
provide logs?
Foreman :: Manual
foreman, I got :
    Warning!
change.
Dominic Cleal
Red Hat Engineering
The output is:
··· --- classes: {} parameters: puppetmaster: master01.test.com hostgroup: Redhat root_pw: foreman_env: production environment: production
viewed via the YAML button on a host’s page) are returning no classes
for your host, or if the Puppet master isn’t configured to execute
node.rb and so it’s returning nothing.
Dominic Cleal
Red Hat Engineering
from
classes
provide logs?
Foreman :: Manual
foreman, I got :
    Warning!
the
change.
Dominic Cleal
Red Hat Engineering
Groups
an
