Foreman-Proxy 1.9.2 SSL Problems
Hi all,
I've got foreman installed on host host1.com and am trying to use
foreman-proxy to retrieve information from the puppet master running on
host2.com (.com's are examples).
Foreman is happily retrieving reports from the puppet runs on host2, but
when I try and setup the proxy and then import classes or environments, I
get the following error in Foreman:
ERF12-2749 [ProxyAPI::ProxyException]: Unable to get environments from
Puppet ([RestClient::NotAcceptable]: 406 Not Acceptable) for proxy
https://host2.com
Checking the proxy error log, I see the following error:
E, [2015-10-28T13:30:03.665340 #31215] ERROR – : Failed to list puppet
environments: SSL_connect returned=1 errno=0 state=SSLv3 read server
certificate B: certificate verify failed
nn.nn.nn.nn - - [28/Oct/2015 13:30:03] "GET /puppet/environments HTTP/1.1"
406 131 0.3124
My /etc/foreman-proxy/settings.yml is (after stripping out the commented
lines) :
··· --- :settings_directory: /etc/foreman-proxy/settings.d :ssl_ca_file: "/var/lib/puppet/ssl/certs/ca.pem" :ssl_certificate: "/var/lib/puppet/ssl/certs/host2.com.pem" :ssl_private_key: "/var/lib/puppet/ssl/private_keys/host2.com.pem" :trusted_hosts: - host1.com :foreman_url: https://host1.com :daemon: true :https_port: 8443 :virsh_network: default :log_level: DEBUG
and /etc/foreman-proxy/settings.d/puppet.yml is :
:enabled: https
:customrun_cmd: /bin/false
:customrun_args: -ay -f -s
:puppet_conf: /etc/puppet/puppet.conf
:puppetssh_command: /usr/bin/puppet agent --onetime --no-usecacheonfailure
:puppetssh_wait: false
:puppet_url: https://host2.com:8140
:ssl_ca_file: “/var/lib/puppet/ssl/certs/ca.pem”
:ssl_certificate: “/var/lib/puppet/ssl/certs/host2.com.pem”
:ssl_private_key: “/var/lib/puppet/ssl/private_keys/host2.com.pem”
Can anyone see anything obviously wrong or suggest what needs to be changed
to get this working?
Simon
> puppet environments: SSL_connect returned=1 errno=0 state=SSLv3 read
> server certificate B: certificate verify failed
> HTTP/1.1" 406 131 0.3124
[snip]
> :enabled: https
These last three settings don't look correct, they should be:
:puppet_ssl_ca:
:puppet_ssl_cert:
:puppet_ssl_key:
They're used when the smart proxy makes SSL calls to the Puppet master,
which is used on Puppet 3.5 or higher when directory environments are in
use. The defaults ought to work for you though, assuming the certname
and hostname match.
The other thing to check is that the Puppet master's certificate has the
same hostname as specified in :puppet_url, which could cause validation
failures.
··· On 28/10/15 13:40, Simon Hanmer wrote:
Dominic Cleal
dominic@cleal.org
Dominic,
changes those 3 field names worked - thanks!
