Hey folks,
I've got a few issues with installing foreman and was hoping someone might
have some ideas on how to approach this.
I've done a fair bit of googling about the errors I have.
System:
Type of System = VMware Virtual Platform
OS Version = CentOS release 6.5 (Final)
things seem to be going ok, but then it errors out:
[ INFO 2014-08-31 00:36:33 verbose]
/usr/lib/ruby/gems/1.8/gems/puppet-3.6.2/lib/puppet/util/command_line.rb:137:in
`run'
/usr/lib/ruby/gems/1.8/gems/puppet-3.6.2/lib/puppet/util/command_line.rb:91:in
`execute'
/usr/lib/ruby/gems/1.8/gems/puppet-3.6.2/bin/puppet:8
[ INFO 2014-08-31 00:36:33 verbose] /usr/bin/puppet:20:in `load'
[ WARN 2014-08-31 00:36:33 verbose] Finished catalog run in 4.55 seconds
[ INFO 2014-08-31 00:36:34 verbose] Puppet has finished, bye!
[ INFO 2014-08-31 00:36:34 verbose] Executing hooks in group post
[ INFO 2014-08-31 00:36:34 verbose] All hooks in group post finished
[ERROR 2014-08-31 00:36:34 verbose] Repeating errors encountered during run:
/Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[localhostname_redacted]:
Could not evaluate: 404 Resource Not Found: <!DOCTYPE HTML PUBLIC
"-//IETF//DTD HTML 2.0//EN">
The full log is at /var/log/foreman-installer/foreman-installer.log
I did install ruby 193 from SCL but I'm not exactly sure how to force the
installer to try using that or if that would help.
I don't get any errors starting or stopping foreman-proxy.
I thought maybe it installed anyway so I checked the https logs - which I
suspect may be a different problem:
[Sat Aug 30 23:39:21 2014] [notice] caught SIGTERM, shutting down
[Sat Aug 30 23:39:23 2014] [error] *** Passenger could not be initialized
because of this error: The 'PassengerRoot' configuration option is not
specified. This option is required, so please specify it. TIP: The correct
value for this option was given to you by
'passenger-install-apache2-module'.
[Sat Aug 30 23:39:23 2014] [notice] suEXEC mechanism enabled (wrapper:
/usr/sbin/suexec)
[Sat Aug 30 23:39:23 2014] [notice] Digest: generating secret for digest
authentication …
[Sat Aug 30 23:39:23 2014] [notice] Digest: done
[Sat Aug 30 23:39:23 2014] [notice] Apache/2.2.15 (Unix) DAV/2
Phusion_Passenger/3.0.21 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured –
resuming normal operations
If I attempt to access the foreman server through the browser I get:
Forbidden
You don't have permission to access / on this server.
I did try creating a /etc/httpd/conf.d/foreman.conf but it didn't work,
and besides I see there are other files put there for foreman.
Any help appreciated.
-mike
