I'm having a weird problem - when trying to connect to my foreman-proxy on
my puppet box to import classes, I get an error. After looking further into
this, it seems that the proxy does not read my settings in my ENC script
(/etc/puppet/node.rb) correctly. These values seem to be validated
in /usr/share/foreman-proxy/lib/proxy/puppet/api_request.rb and if I edit
this file and hardcode my node.rb values there as the fallback default,
then it works. The values in question are @url, @ssl_ca, @ssl_cert and
@ssl_key. I've checked permissions on node.rb and thats fine.
Anyone recognizing this problem or have an idea what it may be?
Cheers,
Adam
> on my puppet box to import classes, I get an error.
Could you share the error?
> After looking
> further into this, it seems that the proxy does not read my settings in
> my ENC script (/etc/puppet/node.rb) correctly. These values seem to be
> validated in /usr/share/foreman-proxy/lib/proxy/puppet/api_request.rb
> and if I edit this file and hardcode my node.rb values there as the
> fallback default, then it works. The values in question are @url,
> @ssl_ca, @ssl_cert and @ssl_key. I've checked permissions on node.rb and
> thats fine.
The Proxy to Puppet API calls are used when using Puppet's directory
environments, and are controlled by :puppet_url and :puppet_ssl_*
settings in /etc/foreman-proxy/settings.yml (settings.d/puppet.yml in
Foreman 1.6). Some information on them is provided here in the 1.6 manual:
http://theforeman.org/manuals/1.6/index.html#4.3.7Puppet
It won't read node.rb settings as they're for different things.
On 21/08/14 07:51, AdamW wrote:
Dominic Cleal
Red Hat Engineering
ah, works like a charm, thanks. The reason i didnt find these settings is
that the rpm (foreman-proxy-1.5.2-1.el6.noarch) does not create a
'settings.yml.rpmnew' file on update when there is an existings
settings.yml. So all I had was my old settings.yml where these settings
does not exist. It would be a good idea I think to build the rpm so it
creates a .rpmnew version of the config file.
Thanks again!
//Adam
I’m having a weird problem - when trying to connect to my foreman-proxy
After looking
@ssl_ca, @ssl_cert and @ssl_key. I’ve checked permissions on node.rb and
thats fine.
The Proxy to Puppet API calls are used when using Puppet’s directory
Foreman :: Manual
It won’t read node.rb settings as they’re for different things.
Dominic Cleal
Red Hat Engineering
"Foreman users" group.
