Foreman-rake db:migrate fails after upgrade to foreman 3.14 (vault plugin)
Problem: foreman-rake db:migrate fails after upgrade to foreman 3.14, This seems to be related to the vault plugin
rpm -qa |grep vault
rubygem-vault-0.12.0-2.el9.noarch
rubygem-foreman_vault-2.0.0-1.fm3_11.el9.noarch
foreman-rake db:migrate --trace
** Invoke db:migrate (first_time)
** Invoke db:load_config (first_time)
** Execute environment
rake aborted!
NameError: uninitialized constant ForemanVault::Engine::VaultConnection
/usr/share/gems/gems/foreman_vault-2.0.0/lib/foreman_vault/engine.rb:46:in `block (4 levels) in <class:Engine>'
/usr/share/foreman/app/registries/foreman/setting_manager.rb:31:in `instance_eval'
/usr/share/foreman/app/registries/foreman/setting_manager.rb:31:in `category'
/usr/share/gems/gems/foreman_vault-2.0.0/lib/foreman_vault/engine.rb:41:in `block (3 levels) in <class:Engine>'
/usr/share/foreman/app/registries/foreman/setting_manager.rb:17:in `instance_eval'
/usr/share/foreman/app/registries/foreman/setting_manager.rb:17:in `define'
/usr/share/foreman/app/registries/foreman/plugin.rb:324:in `settings'
/usr/share/gems/gems/foreman_vault-2.0.0/lib/foreman_vault/engine.rb:40:in `block (2 levels) in <class:Engine>'
/usr/share/foreman/app/registries/foreman/plugin.rb:92:in `instance_eval'
/usr/share/foreman/app/registries/foreman/plugin.rb:92:in `register'
/usr/share/gems/gems/foreman_vault-2.0.0/lib/foreman_vault/engine.rb:23:in `block in <class:Engine>'
/usr/share/gems/gems/railties-7.0.8.7/lib/rails/initializable.rb:32:in `instance_exec'
/usr/share/gems/gems/railties-7.0.8.7/lib/rails/initializable.rb:32:in `run'
/usr/share/foreman/config/initializers/0_print_time_spent.rb:45:in `block in run'
/usr/share/foreman/config/initializers/0_print_time_spent.rb:17:in `benchmark'
/usr/share/foreman/config/initializers/0_print_time_spent.rb:45:in `run'
/usr/share/gems/gems/railties-7.0.8.7/lib/rails/initializable.rb:61:in `block in run_initializers'
/usr/share/ruby/tsort.rb:228:in `block in tsort_each'
/usr/share/ruby/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
/usr/share/ruby/tsort.rb:431:in `each_strongly_connected_component_from'
/usr/share/ruby/tsort.rb:349:in `block in each_strongly_connected_component'
/usr/share/ruby/tsort.rb:347:in `each'
/usr/share/ruby/tsort.rb:347:in `call'
/usr/share/ruby/tsort.rb:347:in `each_strongly_connected_component'
/usr/share/ruby/tsort.rb:226:in `tsort_each'
/usr/share/ruby/tsort.rb:205:in `tsort_each'
/usr/share/gems/gems/railties-7.0.8.7/lib/rails/initializable.rb:60:in `run_initializers'
/usr/share/gems/gems/railties-7.0.8.7/lib/rails/application.rb:372:in `initialize!'
/usr/share/gems/gems/railties-7.0.8.7/lib/rails/railtie.rb:226:in `public_send'
/usr/share/gems/gems/railties-7.0.8.7/lib/rails/railtie.rb:226:in `method_missing'
/usr/share/foreman/config/environment.rb:5:in `<top (required)>'
<internal:/usr/share/rubygems/rubygems/core_ext/kernel_require.rb>:85:in `require'
/usr/share/gems/gems/polyglot-0.3.5/lib/polyglot.rb:65:in `require'
/usr/share/gems/gems/zeitwerk-2.6.18/lib/zeitwerk/kernel.rb:34:in `require'
/usr/share/gems/gems/railties-7.0.8.7/lib/rails/application.rb:348:in `require_environment!'
/usr/share/gems/gems/railties-7.0.8.7/lib/rails/application.rb:506:in `block in run_tasks_blocks'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:281:in `block in execute'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:281:in `each'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:281:in `execute'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:199:in `synchronize'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:199:in `invoke_with_call_chain'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:243:in `block in invoke_prerequisites'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:241:in `each'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:241:in `invoke_prerequisites'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:218:in `block in invoke_with_call_chain'
/usr/share/gems/gems/rake-13.0.3/lib/rake/task.rb:188:in `invoke'
/usr/share/gems/gems/rake-13.0.3/lib/rake/application.rb:160:in `invoke_task'
/usr/share/gems/gems/rake-13.0.3/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/usr/share/gems/gems/rake-13.0.3/lib/rake/application.rb:116:in `each'
/usr/share/gems/gems/rake-13.0.3/lib/rake/application.rb:116:in `block in top_level'
/usr/share/gems/gems/rake-13.0.3/lib/rake/application.rb:125:in `run_with_threads'
/usr/share/gems/gems/rake-13.0.3/lib/rake/application.rb:110:in `top_level'
/usr/share/gems/gems/rake-13.0.3/lib/rake/application.rb:83:in `block in run'
/usr/share/gems/gems/rake-13.0.3/lib/rake/application.rb:186:in `standard_exception_handling'
/usr/share/gems/gems/rake-13.0.3/lib/rake/application.rb:80:in `run'
/usr/share/gems/gems/rake-13.0.3/exe/rake:27:in `<top (required)>'
/usr/bin/rake:25:in `load'
/usr/bin/rake:25:in `<main>'
Tasks: TOP => db:migrate => db:load_config => environment
Foreman and Proxy versions: 3.14
Foreman and Proxy plugin versions: 3.14
Distribution and version: Red Hat Enterprise Linux release 9.5 (Plow) 5.14.0-503.23.1.el9_5.x86_64
Hey @orelops , a PR for the fix is open. Which will be merged some time this week.
feat: add zeitwerk support by ochnerd · Pull Request #63 · dm-drogeriemarkt/foreman_vault · GitHub. The support for the new zeitwerk loader is missing.
