Katello 3.13 RC2
Foreman 1.23
CentOS 7.7.1908
Ruby 2.6.3
For reasons I will not get into I had to upgrade to Ruby 2.6.3. To do this I installed RVM and let it upgrade the base ruby to 2.6.3. After that I installed the foreman-hooks plugin using yum install. That seemed to work fine.
Foreman-hooks aside everything in foreman/katello seems to be working fine. I just run into issues when running foreman-hooks commands. Like this one:
[root@fm home]# foreman-rake hooks:objects
rake aborted!
Gem loading error: Unable to activate scoped_search-4.1.7, because activerecord-4.1.0 conflicts with activerecord (>= 4.2.0)
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/output.rb:13:in `strict_err'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/runtime.rb:46:in `rescue in block in system_require'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/runtime.rb:39:in `block in system_require'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/runtime.rb:37:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/runtime.rb:37:in `system_require'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext.rb:19:in `block in system_require'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext.rb:14:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext.rb:14:in `system_require'
/usr/share/foreman/config/application.rb:17:in `<top (required)>'
/usr/share/foreman/Rakefile:1:in `<top (required)>'
/usr/local/rvm/gems/ruby-2.6.3/gems/rake-12.3.3/exe/rake:27:in `<top (required)>'
Caused by:
Gem::ConflictError: Unable to activate scoped_search-4.1.7, because activerecord-4.1.0 conflicts with activerecord (>= 4.2.0)
/usr/local/rvm/gems/ruby-2.6.3/gems/activesupport-4.1.0/lib/active_support/dependencies.rb:247:in `block in require'
/usr/local/rvm/gems/ruby-2.6.3/gems/activesupport-4.1.0/lib/active_support/dependencies.rb:232:in `load_dependency'
/usr/local/rvm/gems/ruby-2.6.3/gems/activesupport-4.1.0/lib/active_support/dependencies.rb:247:in `require'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/runtime.rb:41:in `block in system_require'
Caused by:
Caused by:
LoadError: cannot load such file -- scoped_search
I have tried searching for the errors but cannot find anything like it.
The above error where its saying “activerecord-4.1.0 conflicts with activerecord (>= 4.2.0)” is not the first error. Previous to that error I was getting errors about activerecord not being the correct version so I tried to do a gem install activerecord = 4.1.0. And that got me the conflicts. Turned out that going to ruby 2.6.3 netted me activerecord 6.0.0.
So my first question is did I do wrong by upgrading to ruby 2.6.3? Is there any way I can fix all of this?
Thanks.
