Good day,
We are using the foreman puppet module to build out additional foreman
servers.
Every agent run the report shows applied 2 restarted 8.
When you look at the report it states:
/Stage[main]/Foreman::Database/Foreman_config_entry[db_pending_migration]/value value
changed 'Successfully encrypted field for Setting::Auth oauth_consumer_key
Successfully decrypted field for Setting::Auth oauth_consumer_key
Successfully encrypted field for Setting::Auth oauth_consumer_secret
Successfully decrypted field for Setting::Auth oauth_consumer_secret
false' to 'false'
notice
/Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate] Triggered
'refresh' from 1 events
notice
/Stage[main]/Foreman::Database/Foreman_config_entry[db_pending_seed]/value value
false' to 'false'
notice
/Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed] Triggered
notice
/Stage[main]/Foreman::Database/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index] Triggered
notice
/Stage[main]/Foreman::Plugin::Memcache/Foreman::Plugin[memcache]/Package[tfm-rubygem-foreman_memcache] Triggered
notice /Stage[main]/Foreman::Service/Anchor[foreman::service_begin] Triggered
notice /Stage[main]/Foreman::Service/Anchor[foreman::service_end] Triggered
notice /Stage[main]/Foreman::Service/Exec[restart_foreman] Triggered
notice /Stage[main]/Foreman::Service/Service[foreman]/ensure ensure changed
'running' to 'stopped'
notice /Stage[main]/Foreman::Service/Service[foreman] Triggered 'refresh'
from 1 events
If we run the foreman-rake db:migrate command from the shell same results.
Does anyone have a suggestion as to what may be causing this or how we can
correct it?
Thank you
It appears this is a known bug currently open.
http://projects.theforeman.org/issues/18200
Hope this helps others.
On Wednesday, May 24, 2017 at 6:25:05 AM UTC-5, Jason McMahan wrote:
> Good day,
> servers.
> false' to 'false'
> notice
> notice
> false' to 'false'
> notice
> notice
> notice
> changed 'running' to 'stopped'
> from 1 events
> correct it?
> Thank you
This bug is specifically about audit entries, not logging.
#19534 reduces the encryption-related logging which may be affecting the
provider.
Dominic Cleal
dominic@cleal.org
