I'm sorry for this but in a previous questions I understand that Foreman
can support REMOTE_USER authentication, but I don't found where is this API
and how it's implemented.
Can you give me a link of this API? or an answer for this problem?
First, to enable SSO with API you would need to enable it, make sure you
change the setting under more -> settings (search for api)
second, the api it self is documented at Foreman
Ohad
"Foreman users" group.
Visit this group at http://groups.google.com/group/foreman-users?hl=en.
Thanks for your fast response.
I have found the "authorize login delegation" in settings and I changed the
flag in true, but I don't understand how it works. After that Apache
validate the authentication in according to CAS and the REMOTE_USER
variable is set, I could doing any operation with foreman if I pass it the
username. Is this right? Is there any example?
> I have found the "authorize login delegation" in settings and I changed the flag in true, but I don't understand how it works. After that Apache validate the authentication in according to CAS and the REMOTE_USER variable is set, I could doing any operation with foreman if I pass it the username. Is this right? Is there any example?
Normally the mod_cas will set an environment variable in the header and then you set this to REMOTE_USER. Sometimes it is actually REMOTE_USER so
there is nothing to do.
Here is an example with mod_shibd we have
SetEnvIf ADFS_LOGIN "(.*)" REMOTE_USER=$1
mod_shibd sets ADFS_LOGIN if and only if mod_shibd accepts the user.
I do not know CAS at all but a 10 second look at
https://wiki.jasig.org/display/CASC/mod_auth_cas
suggests there is nothing to do and REMOTE_LOGIN will be set for you.
Il giorno mercoledì 17 aprile 2013 10:33:25 UTC+2, ohad ha scritto:
On Wed, Apr 17, 2013 at 11:31 AM, Euclideo ivanosi...@gmail.com wrote:
I’m sorry for this but in a previous questions I understand that Foreman can support REMOTE_USER authentication, but I don’t found where is this API and how it’s implemented.Can you give me a link of this API? or an answer for this problem?
First, to enable SSO with API you would need to enable it, make sure you change the setting under more -> settings (search for api)
Ohad
To unsubscribe from this group and stop receiving emails from it, send an email to foreman-user...@googlegroups.com.
To post to this group, send email to forema...@googlegroups.com.
For more options, visit https://groups.google.com/groups/opt_out.–
