I am attempting to install and use foreman_slack on foreman 1.16. I’ve installed the plugin
[root@foreman-dev]# gem install foreman_slack
Fetching: slack-notifier-2.3.2.gem (100%)
Successfully installed slack-notifier-2.3.2
Fetching: foreman_slack-0.0.3.gem (100%)
Successfully installed foreman_slack-0.0.3
Parsing documentation for slack-notifier-2.3.2
Installing ri documentation for slack-notifier-2.3.2
Parsing documentation for foreman_slack-0.0.3
Installing ri documentation for foreman_slack-0.0.3
2 gems installed
And restarted foreman foreman-proxy and httpd. However I can’t see the /settings tab “Slack” that is mentioned.
Is there a way to list plugins installed to see if it’s just not seeing it?
You can list plugins on the About > Plugins page to check if it’s loading at all.
The original author of the Slack plugin, Shlomi, hasn’t been active for quite a while - the repo hasn’t seen commits since last year. @Ori_Rabin do you know how to ping him? Even if it’s just to confirm the plugin is in need of a new maintainer…
Shlomi is looking at open prs on the plugin but I’ll reach out to see if we can add another maintainer.
Thanks for the “About -> Plugins” location, did not know it existed!
Sure nuff, not there. I didn’t think to check that the plugin might be to old to be compatible with 1.16.
For what it’s worth, the plugin does work in 1.15.1; (I should really upgrade…)
Perhaps I installed incorrectly, the method I used was “gem install foreman_slack” after adding the file to bundles.d.
It seemed to install the correct files but nothing showed after restarted foreman/proxy/httpd/etc.
Straight gem install
generally won’t work - see section 2.3 of Foreman :: Plugin Manuals for OS-specific install instructions.
Im having issues with this plugin on 1.17.1.
It shows in about -> plugins, but i dont get any messages to slack after 1.17 upgrade.
(Running 0.0.3)
What i can get from the production.log regarding slack looks like some widget specifics:
| * "/usr/share/foreman/app/views"
| * "/usr/share/foreman/vendor/ruby/2.3.0/bundler/gems/foreman_slack-1d01c40ea6eb/app/views"
| * "/usr/share/foreman/vendor/ruby/2.3.0/gems/foreman-tasks-0.11.2/app/views"
| * "/usr/share/foreman/vendor/ruby/2.3.0/gems/foreman_discovery-11.0.0/app/views"
| * "/usr/share/foreman/vendor/ruby/2.3.0/gems/foreman_setup-6.0.0/app/views"
| * "/usr/share/foreman/vendor/ruby/2.3.0/gems/apipie-rails-0.5.8/app/views"
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.4/lib/action_view/path_set.rb:46:in `find'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.4/lib/action_view/lookup_context.rb:116:in `find'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.4/lib/action_view/renderer/partial_renderer.rb:421:in `find_template'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.4/lib/action_view/renderer/partial_renderer.rb:416:in `find_partial'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.4/lib/action_view/renderer/partial_renderer.rb:297:in `render'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.4/lib/action_view/renderer/renderer.rb:47:in `render_partial'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.4/lib/action_view/renderer/renderer.rb:21:in `render'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:103:in `_render_template'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/streaming.rb:217:in `_render_template'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:83:in `render_to_body'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/renderers.rb:141:in `render_to_body'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/abstract_controller/rendering.rb:24:in `render'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:36:in `render'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:44:in `block (2 levels) in render'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.4/lib/active_support/core_ext/benchmark.rb:12:in `block in ms'
| /usr/lib/ruby/2.3.0/benchmark.rb:308:in `realtime'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.4/lib/active_support/core_ext/benchmark.rb:12:in `ms'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:44:in `block in render'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:87:in `cleanup_view_runtime'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:29:in `cleanup_view_runtime'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:43:in `render'
| /usr/share/foreman/app/controllers/dashboard_controller.rb:19:in `show'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:in `process_action'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in `process_action'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:108:in `block in run_callbacks'
| /usr/share/foreman/app/controllers/concerns/application_shared.rb:15:in `set_timezone'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
| /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
| /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/audited-4.5.0/lib/audited/sweeper.rb:14:in `around'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:135:in `run_callbacks'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:in `process_action'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in `process_action'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `block in instrument'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `instrument'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in `process'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:in `process'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:in `dispatch'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in `dispatch'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in `serve'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:in `block in serve'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `each'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `serve'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/apipie-rails-0.5.8/lib/apipie/static_dispatcher.rb:65:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/apipie-rails-0.5.8/lib/apipie/extractor/recorder.rb:136:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/apipie-rails-0.5.8/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
| /usr/share/foreman/lib/middleware/catch_json_parse_errors.rb:8:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/etag.rb:25:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/conditional_get.rb:25:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/head.rb:12:in `call'
| /usr/share/foreman/lib/middleware/session_safe_logging.rb:17:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in `run_callbacks'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:36:in `call_app'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:26:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
| /usr/share/foreman/lib/middleware/tagged_logging.rb:18:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/runtime.rb:22:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.4/lib/active_support/cache/strategy/local_cache_middleware.rb:27:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/executor.rb:12:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/static.rb:125:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/secure_headers-3.7.3/lib/secure_headers/middleware.rb:12:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.4/lib/rails/engine.rb:522:in `call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in `block in call'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `each'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `call'
| /usr/lib/ruby/vendor_ruby/phusion_passenger/rack/thread_handler_extension.rb:97:in `process_request'
| /usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler/thread_handler.rb:152:in `accept_and_process_next_request'
| /usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler/thread_handler.rb:113:in `main_loop'
| /usr/lib/ruby/vendor_ruby/phusion_passenger/request_handler.rb:416:in `block (3 levels) in start_threads'
| /usr/lib/ruby/vendor_ruby/phusion_passenger/utils.rb:113:in `block in create_thread_and_abort_on_exception'
| /usr/share/foreman/vendor/ruby/2.3.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
ekohl
October 3, 2018, 10:45am
9
That plugin hasn’t been updated in a while. I wonder if it could be implemented through foreman_hooks as well.
danoe
August 21, 2019, 8:06pm
10
Thanks for this hint. Now I’m using foreman_hooks and their python example
I’m hooking into config_report/after_create
to report failed puppet runs and runs with high number of changes.
and using slackclient to send the message simply with this
def send_to_slack(message):
client = slack.WebClient(
token=api_token)
response = client.chat_postMessage(
channel=channel,
blocks=message)
assert response["ok"]
