I ran into issues/confusion creating a new host in foretello and am trying to determine what the intended correct behavior is supposed to be. Depending on the answers below, it seems there are some big gaps in how the UI validates objects during creation and use.
True or false?
In foretello, organizations and locations are required to be enabled.
Organization nesting is forced disabled.
Location nesting is forced enabled.
All foreman resources are required to belong to an organization.
All katello resources are required to belong to an organization.
All foreman resources are required to belong to a location.
All katello resources are required to belong to a location.
Resources, be they foreman or katello, may only belong to one and only one organization.
Resources, be they foreman or katello, may only belong to one and only one location.
@thomasmckay
“The leader must aim high, see big, judge widely, thus setting himself apart form the ordinary people who debate in narrow confines.” ~ Charles De Gaulle
“Leadership is about making others better as a result of your presence and making sure that impact lasts in your absence.” ~ Harvard Business School
> True or false?
> 1. In foretello, organizations and locations are required to be enabled.
IMHO false, but its not a bad idea to be the default.
> 2. Organization nesting is forced disabled.
True for the first version ( or until katello adds support for it).
> 3. Location nesting is forced enabled.
Not forced, but it's a feature added part 1.4.
> 4. All foreman resources are required to belong to an organization.
False most but not all, some are indirectly assign - reports facts etc.
Others not implemented - audits some are global - roles
> 5. All katello resources are required to belong to an organization.
> 6. All foreman resources are required to belong to a location.
Same as #4 (assuming its enable as in #1)
> 7. All katello resources are required to belong to a location.
I don't think katello is aware of the location currently.
> 8. Resources, be they foreman or katello, may only belong to one and only
one organization.
False, true only for hosts
> 9. Resources, be they foreman or katello, may only belong to one and only
one location.
Same as #8
> @thomasmckay
> "The leader must aim high, see big, judge widely, thus setting himself
apart form the ordinary people who debate in narrow confines." ~ Charles De
Gaulle
> "Leadership is about making others better as a result of your presence
and making sure that impact lasts in your absence." ~ Harvard Business
School
"foreman-dev" group.
On Mar 30, 2014 6:20 PM, "Tom McKay" wrote:
> > True or false?
> enabled.
Today I think true, long term… we should discuss but I would suggest false.
trye
true
true
> only one location.
> Same as #8
I think what you are seeing here is that katello assumed strict
tenancy… where foreman did not. I tend to think long term we may want
to look more to foreamns model… but that will require changing katello,
candlepin, and possibly pulp.
bk
On 03/30/2014 04:05 PM, Ohad Levy wrote:
> On Mar 30, 2014 6:20 PM, "Tom McKay" > wrote:
My issue/confusion is that creating a host required the selection of a location, yet not all of the resources required to specify with the org required a location. Which is correct, all resources must have a location or it's optional? If a host must have a location, and the other resources entire purpose is for hosts to use, why would any resource not also require that at least one location be specified? There's a disconnect there, right?
----- Original Message -----
> Comments below
> > > True or false?
> > > 1. In foretello, organizations and locations are _required_ to be
> > enabled.
> Today I think true, long term.. we should discuss but I would suggest false.
> trye
> true
> true
> > only one location.
> > Same as #8
> tenancy.. where foreman did not. I tend to think long term we may want
> to look more to foreamns model.. but that will require changing katello,
> - bk
> email to foreman-dev+unsubscribe@googlegroups.com.
I'm not sure locations should be on by default, as it probably
is not the key feature, but adds a lot of additional steps
to be able to start provisioning (since once enabled, you can't
create a host without location enabled).
The fix for me would be either fixing #4712 and making the locations
disabled by default or creating a "default location", not scoping
anything: just to make foreman happy, when I really don't care about locations.
– Ivan
> > Comments below
> > > > True or false?
> > > enabled.
> > false.
> > trye
> > true
> > true
> > > only one location.
> > > Same as #8
> > - bk
> it's optional? If a host _must_ have a location, and the other resources
> Enabling locations by default seems to be a consequence of this bug
> http://projects.theforeman.org/issues/4712
> locations.
> -- Ivan
> > > Comments below
> > > > > True or false?
> > > > enabled.
> > > false.
> > > trye
> > > true
> > > true
> > > > only one location.
> > > > Same as #8
> > > - bk
> > or
On 03/31/2014 11:53 AM, Ivan Necas wrote:
> I've filed an issue against that
> http://projects.theforeman.org/issues/4975
> -- Ivan
>> locations.
>> -- Ivan
>>>> Comments below
>>>>> > True or false?
>>>>> enabled.
>>>> false.
>>>> trye
>>>> true
>>>> true
>>>>> only one location.
>>>>> Same as #8
>>>> - bk
>>> or
