I have the following in my puppet.conf
[master]
autosign = $confdir/autosign.conf { mode = 664 }
reports = foreman
external_nodes = /etc/puppet/node.rb
node_terminus = exec
ca = true
ssldir = /var/lib/puppet/ssl
certname = <MY_MACHINE_FQDN>
strict_variables = false
environmentpath = /etc/puppet/environments
basemodulepath =
/etc/puppet/environments/$environment/modules/forge:/etc/puppet/environments/$environment/modules/local
When I curl the puppet foreman proxy I get environments reported
curl -k -sS https://<MY_MACHINE_FQDN>:8140/v2.0/environments --cert
/var/lib/puppet/ssl/certs/<MY_MACHINE_FQDN>.pem --key
/var/lib/puppet/ssl/private_keys/<MY_MACHINE_FQDN>.pem -X GET
http://localhost:8443/puppet/environments
My understanding from this is that the proxy has correctly found the
environments
I am running Forman 1.6.1-1
on CentOS release 6.5
It was installed with installer defaults
Any input welcome
puppet version is 3.7.2 (community)
I'm afraid I don't see any output from your curl command there, i'd expect
an array. Did the mailing list just mangle that part of your mail, or did
it really return nothing?
Greg
The json output had the search path in it for both the module sub paths <environment>/modules/forge
and <environment>/modules/local unfortunately Foreman only parses
<environment>/modules and does not seem to honor the search paths returned
by puppet. As a work around I have moved my modules into <environment>/modules
and all works as expected
> Greg
I am attempting to raise this as a bug but not having a lot of luck with
redmine.
Can newly created users raise bug or do I need to send them to a mailing
list?
Any user registered to Redmine should be able to create a bug.
http://projects.theforeman.org/projects/foreman/issues/new
If not, please say exactly what problem you're having.
Incidentally, regarding the problem, I think it's probably that the
smart proxy isn't interpolating $environment in a modulepath returned
from Puppet. I had expected Puppet to do that, evidently not.
> redmine.
> list?
Dominic Cleal
Red Hat Engineering
Bug #8162 raised
Thank you I just could not see navigation to get a new bug
> > redmine.
> > list?
> Dominic Cleal
> Red Hat Engineering
Had to choose a project before getting a new issue tab
On Wednesday, 29 October 2014 16:55:46 UTC, Robert Mortimer wrote:
> Bug #8162 raised
>> with
>> > redmine.
>> mailing
>> > list?
>> Dominic Cleal
>> Red Hat Engineering
