General Bug in foreman-installer? Even fresh install does not work anymore
Ok i found the problem, but i do not know really how to handle it …
It seems that the foreman-installer fails on a might correct systemwide proxy configuration.
I set my proxy like this:
/etc/profile.d/proxy.sh
export http_proxy=http://my.proxy.com:8000
export https_proxy=http://my.proxy.com:8000
visudo
Defaults env_keep += "http_proxy"
Defaults env_keep += “https_proxy”
i know that the proxy configuration works because yum and other applications can install over http and https. But foreman-installer fails.
If i do not set a systemwide proxy and just configure yum in /etc/yum.conf with the proxy, then the foreman-installer does not fails.
is there something i do not know?
So that’s what I suggested to check earlier:
I think we should consider copying the katello check for proxies because it’s known to cause problems:
https://github.com/Katello/katello-installer/blob/master/checks/env_variables.rb
That is indeed the recommended solution.
@ekohl
ok thanks for your answer and your help and patience. Honestly, i think my english was not so good at this point. I interpreted your text with the proxy that i should look if the communication over a proxy is not blocked (= the proxy server is set correctly) :dizzy_face: … Sorry for that!
a check as your show up would be great.
best regards
No problem. Written communication tends to be hard and things get lost in translations.
