One of my systems is air gapped. The system is a new build and getting the repos set up for the 1st time. I export my content from the connected system by running a full export of the library. The data is then transferred to the disconnected system in the imports folder. I then run: hammer content-import library --organization"<name_here>" --path=/var/lib/pulp/imports/
After about 20 mins the process fails with: Error: 1 subtask(s) failed the task group /pulp/api/v3/task-groups/894b1e7c-xxx-xxx-xxx-xxx/.
By reviewing Montior>Tasks and finding the import task that was run, I can find more info about the failure. From there I can review the Errors tab and see the Action:, Input:, Output:, Exception:, and Backtrace:
Can anyone provide some general troubleshooting hints and tips? Due to the type of system I am unable to pull logs for upload easily. It requires approval by authorities above me. This is why I am asking a general question. Sorry I am not able to be more specific at this time.
The Exception section says this: Katello::Errors::Pulp3Error: Error: 1 subtask(s) failed the task group /pulp/api/v3/task-groups/894b1e7c-xxx-xxx-xxx-xxx/.
From the Task tab of the failed task, click on Dynflow console button.
In the popup Dynflow window, click on Run tab. You should see a list of actions.
The failed action is in red. Click on it that will show what error you run into.
Ok, I don’t see anything in Red in the Dynflow console. All the items are in orange/blue but no red. Also, every action listed in the console has a status of (success). Now I am a little more confused.
My understanding is that importing a library will also import all the RPMs located in the repository. Is my understanding correct? Maybe I have it wrong…
I do see the Products and Repos getting created when running the content-import job.
Let’s find out the status of the failed task-group. Please replace with your task-group id before running the command. curl https://`hostname`/pulp/api/v3/task-groups/<894b1e7c-xxx-xxx-xxx-xxx>/ --cert /etc/pki/katello/certs/pulp-client.crt --key /etc/pki/katello/private/pulp-client.key | python -m json.tool
This was perfect. It allowed me to see what the problem really was. My humble .02 worth - pin this. Getting to the bottom of a cryptic error message was invaluable in solving the problem. By seeing the actual error message that was buried two layers deep I was able to resolve my issue.
