Hi guys ;
i want to provision many PCs in my Company , and every time i deploy
installation from foreman the un attended machine dont have any GUI , its a
minimal installation , and i dont now where is the problem , i do this many
times with Ubuntu and centos , so any one have any ideas ?
thanks
The %packages section of the kickstart template you are using needs to be edited to add the relevant desktop package group. Can't remember off the top of my head, but I think it's @gnome-desktop or @kde-desktop.
You might also need something in the %post section to ensure the graphical.target is reached by systemd (I've not installed RHEL7/CentOS desktop systems from Satellite, so not sure about this part)
You should be able to just remove the "skipx" option in the kickstart [template] (and install a desktop environment). If you install a desktop and don't have skipx the default boot target will be graphical.
https://access.redhat.com/documentation/en-US/Red_Hat_Enterprise_Linux/7/html/Installation_Guide/sect-kickstart-syntax.html
(search for "skipx")
