In the Katello GUI you can go to All Hosts then select a host and give it a Hostgroup name when the only thing configured in the Hostgroup is the name of the group.
When you try the following via hammer however:
hammer host update --name td3us1tdsmd01-host01.***.net --hostgroup-id 6
The result is:
Could not update the host:
Content view can’t be blank
Lifecycle environment can’t be blank
I am running:
foreman-1.17.1-1.el7
katello-3.6.0-3.el7
I am not happy that hammer is doing this as I just want to use the hostgoup for an ansible script. But should not both the GUI and hammer produce the same results?
Thanks.
