This is more a question than support request. We are using hammer to spin-up vm from templates and it works fine.
The problem we are having is: if we execute a second instance of hammer while is provisioning a vm then the second one fails to create properly. We are using libvirt as hypervisor
Is this normal?
Thanks!
Alex
