Using ‘hammer -u user repository upload-content --organization org --product ‘product’ --name ‘repo’ --path ./uploaded.rpm’ or the ‘–id’ method of the command or the UI upload, the command is successful, Tasks all show success, logs all show success - but content does not appear in target repository. This is a custom repo only with no upstream or sync.
Uploaded packages should appear in the listed repository.
3.1.1, Katello 4.3
CentOS 7.9.2009
This worked without issue on previous 2.x releases. For testing, I have created new products, with new repos (no upstream URL of course, no sync) - same result each time. What is really strange is that every time I create a new, empty repo, one package does appear after creation - python36-dmlite. Yet, if I search for this package, it only comes up where it should, in EPEL7 repo. Production.log is below with the snippet pertaining to upload. There is a ‘delete’ message, but I assume that is for the upload process, not the file…or maybe I am wrong.
2022-03-25T11:29:54 [I|app|d6bc9c97] Completed 200 OK in 263ms (Views: 31.6ms | ActiveRecord: 34.0ms | Allocations: 49593)
2022-03-25T11:29:54 [I|app|7a1614ea] Started POST "/katello/api/repositories/236/content_uploads" for 1.2.3.4 at 2022-03-25 11:29:54 -0400
2022-03-25T11:29:54 [I|app|7a1614ea] Processing by Katello::Api::V2::ContentUploadsController#create as JSON
2022-03-25T11:29:54 [I|app|7a1614ea] Parameters: {"size"=>15215948, "checksum"=>"6d48d467ce9e76156167afd247fe773c3171136a93fbca1079b7235f1e861735", "content_type"=>nil, "api_version"=>"v2", "repository_id"=>"236", "content_upload"=>{"size"=>15215948, "checksum"=>"6d48d467ce9e76156167afd247fe773c3171136a93fbca1079b7235f1e861735", "content_type"=>nil}}
2022-03-25T11:29:54 [I|app|7a1614ea] Authorized user testuser(Test User)
2022-03-25T11:29:54 [I|app|7a1614ea] Completed 200 OK in 357ms (Views: 0.3ms | ActiveRecord: 17.5ms | Allocations: 65237)
2022-03-25T11:29:55 [I|app|23d646e9] Started PUT "/katello/api/repositories/236/content_uploads/81e72f00-3370-48c9-b3d1-1d391c1130be" for 1.2.3.4 at 2022-03-25 11:29:55 -0400
2022-03-25T11:29:55 [I|app|23d646e9] Processing by Katello::Api::V2::ContentUploadsController#update as JSON
2022-03-25T11:29:55 [I|app|23d646e9] Parameters: {"offset"=>"0", "content"=>"[FILTERED]", "size"=>"15215948", "api_version"=>"v2", "repository_id"=>"236", "id"=>"81e72f00-3370-48c9-b3d1-1d391c1130be"}
2022-03-25T11:29:55 [I|app|23d646e9] Authorized user testuser(Test User)
2022-03-25T11:29:55 [I|app|23d646e9] Completed 204 No Content in 300ms (ActiveRecord: 17.8ms | Allocations: 35929)
2022-03-25T11:29:55 [I|app|515657a4] Started PUT "/katello/api/repositories/236/content_uploads/81e72f00-3370-48c9-b3d1-1d391c1130be" for 1.2.3.4 at 2022-03-25 11:29:55 -0400
2022-03-25T11:29:55 [I|app|515657a4] Processing by Katello::Api::V2::ContentUploadsController#update as JSON
2022-03-25T11:29:55 [I|app|515657a4] Parameters: {"offset"=>"2500000", "content"=>"[FILTERED]", "size"=>"15215948", "api_version"=>"v2", "repository_id"=>"236", "id"=>"81e72f00-3370-48c9-b3d1-1d391c1130be"}
2022-03-25T11:29:55 [I|app|515657a4] Authorized user testuser(Test User)
2022-03-25T11:29:55 [I|app|515657a4] Completed 204 No Content in 292ms (ActiveRecord: 15.2ms | Allocations: 35912)
2022-03-25T11:29:56 [I|app|e541fd94] Started PUT "/katello/api/repositories/236/content_uploads/81e72f00-3370-48c9-b3d1-1d391c1130be" for 1.2.3.4 at 2022-03-25 11:29:56 -0400
2022-03-25T11:29:56 [I|app|e541fd94] Processing by Katello::Api::V2::ContentUploadsController#update as JSON
2022-03-25T11:29:56 [I|app|e541fd94] Parameters: {"offset"=>"5000000", "content"=>"[FILTERED]", "size"=>"15215948", "api_version"=>"v2", "repository_id"=>"236", "id"=>"81e72f00-3370-48c9-b3d1-1d391c1130be"}
2022-03-25T11:29:56 [I|app|e541fd94] Authorized user testuser(Test User)
2022-03-25T11:29:56 [I|app|e541fd94] Completed 204 No Content in 312ms (ActiveRecord: 21.2ms | Allocations: 36161)
2022-03-25T11:29:56 [I|app|dac8726b] Started PUT "/katello/api/repositories/236/content_uploads/81e72f00-3370-48c9-b3d1-1d391c1130be" for 1.2.3.4 at 2022-03-25 11:29:56 -0400
2022-03-25T11:29:56 [I|app|dac8726b] Processing by Katello::Api::V2::ContentUploadsController#update as JSON
2022-03-25T11:29:56 [I|app|dac8726b] Parameters: {"offset"=>"7500000", "content"=>"[FILTERED]", "size"=>"15215948", "api_version"=>"v2", "repository_id"=>"236", "id"=>"81e72f00-3370-48c9-b3d1-1d391c1130be"}
2022-03-25T11:29:57 [I|app|dac8726b] Authorized user testuser(Test User)
2022-03-25T11:29:57 [I|app|dac8726b] Completed 204 No Content in 293ms (ActiveRecord: 14.9ms | Allocations: 35889)
2022-03-25T11:29:57 [I|app|49782b37] Started PUT "/katello/api/repositories/236/content_uploads/81e72f00-3370-48c9-b3d1-1d391c1130be" for 1.2.3.4 at 2022-03-25 11:29:57 -0400
2022-03-25T11:29:57 [I|app|49782b37] Processing by Katello::Api::V2::ContentUploadsController#update as JSON
2022-03-25T11:29:57 [I|app|49782b37] Parameters: {"offset"=>"10000000", "content"=>"[FILTERED]", "size"=>"15215948", "api_version"=>"v2", "repository_id"=>"236", "id"=>"81e72f00-3370-48c9-b3d1-1d391c1130be"}
2022-03-25T11:29:57 [I|app|49782b37] Authorized user testuser(Test User)
2022-03-25T11:29:57 [I|app|49782b37] Completed 204 No Content in 295ms (ActiveRecord: 16.3ms | Allocations: 35952)
2022-03-25T11:29:58 [I|app|cc37d534] Started PUT "/katello/api/repositories/236/content_uploads/81e72f00-3370-48c9-b3d1-1d391c1130be" for 1.2.3.4 at 2022-03-25 11:29:58 -0400
2022-03-25T11:29:58 [I|app|cc37d534] Processing by Katello::Api::V2::ContentUploadsController#update as JSON
2022-03-25T11:29:58 [I|app|cc37d534] Parameters: {"offset"=>"12500000", "content"=>"[FILTERED]", "size"=>"15215948", "api_version"=>"v2", "repository_id"=>"236", "id"=>"81e72f00-3370-48c9-b3d1-1d391c1130be"}
2022-03-25T11:29:58 [I|app|cc37d534] Authorized user testuser(Test User)
2022-03-25T11:29:58 [I|app|cc37d534] Completed 204 No Content in 308ms (ActiveRecord: 20.7ms | Allocations: 36076)
2022-03-25T11:29:58 [I|app|04069122] Started PUT "/katello/api/repositories/236/content_uploads/81e72f00-3370-48c9-b3d1-1d391c1130be" for 1.2.3.4 at 2022-03-25 11:29:58 -0400
2022-03-25T11:29:58 [I|app|04069122] Processing by Katello::Api::V2::ContentUploadsController#update as JSON
2022-03-25T11:29:58 [I|app|04069122] Parameters: {"offset"=>"15000000", "content"=>"[FILTERED]", "size"=>"15215948", "api_version"=>"v2", "repository_id"=>"236", "id"=>"81e72f00-3370-48c9-b3d1-1d391c1130be"}
2022-03-25T11:29:58 [I|app|04069122] Authorized user testuser(Test User)
2022-03-25T11:29:58 [I|app|04069122] Completed 204 No Content in 271ms (ActiveRecord: 16.7ms | Allocations: 34507)
2022-03-25T11:29:58 [I|app|46636ba5] Started PUT "/katello/api/repositories/236/import_uploads" for 1.2.3.4 at 2022-03-25 11:29:58 -0400
2022-03-25T11:29:58 [I|app|46636ba5] Processing by Katello::Api::V2::RepositoriesController#import_uploads as JSON
2022-03-25T11:29:58 [I|app|46636ba5] Parameters: {"uploads"=>[{"id"=>"81e72f00-3370-48c9-b3d1-1d391c1130be", "content_unit_id"=>nil, "name"=>"sample1.noarch.rpm", "size"=>15215948, "checksum"=>"6d48d467ce9e76156167afd247fe773c3171136a93fbca1079b7235f1e861735"}], "publish_repository"=>true, "sync_capsule"=>true, "api_version"=>"v2", "id"=>"236", "repository"=>{}}
2022-03-25T11:29:58 [I|app|46636ba5] Authorized user testuser(Test User)
2022-03-25T11:29:58 [I|bac|46636ba5] Task {label: , id: bee5baec-bb91-43b2-b518-529a9c560970, execution_plan_id: d71627a0-4381-4019-850a-dad5250d970a} state changed: pending
2022-03-25T11:29:58 [I|bac|46636ba5] Task {label: Actions::Katello::Repository::ImportUpload, id: bee5baec-bb91-43b2-b518-529a9c560970, execution_plan_id: d71627a0-4381-4019-850a-dad5250d970a} state changed: planning
2022-03-25T11:29:59 [I|bac|46636ba5] Task {label: Actions::Katello::Repository::ImportUpload, id: bee5baec-bb91-43b2-b518-529a9c560970, execution_plan_id: d71627a0-4381-4019-850a-dad5250d970a} state changed: planned
2022-03-25T11:29:59 [I|bac|46636ba5] Task {label: Actions::Katello::Repository::ImportUpload, id: bee5baec-bb91-43b2-b518-529a9c560970, execution_plan_id: d71627a0-4381-4019-850a-dad5250d970a} state changed: running
2022-03-25T11:30:01 [I|aud|46636ba5] Katello::Repository (236) update event on publication_href /pulp/api/v3/publications/rpm/rpm/5bd6daff-900c-44d8-832c-d94fab117714/, /pulp/api/v3/publications/rpm/rpm/faf23363-70bd-4a1a-b069-d9620544c45c/
2022-03-25T11:30:02 [I|bac|46636ba5] Task {label: , id: b1a5cec7-d7de-46c5-b6c9-2c3c35870760, execution_plan_id: 69ac8304-9da7-45d8-baeb-28d6b7bdd0b0} state changed: pending
2022-03-25T11:30:02 [I|bac|46636ba5] Task {label: Actions::Katello::Repository::CapsuleSync, id: b1a5cec7-d7de-46c5-b6c9-2c3c35870760, execution_plan_id: 69ac8304-9da7-45d8-baeb-28d6b7bdd0b0} state changed: planning
2022-03-25T11:30:02 [I|bac|46636ba5] Task {label: Actions::Katello::Repository::CapsuleSync, id: b1a5cec7-d7de-46c5-b6c9-2c3c35870760, execution_plan_id: 69ac8304-9da7-45d8-baeb-28d6b7bdd0b0} state changed: planned
2022-03-25T11:30:02 [I|bac|46636ba5] Task {label: Actions::Katello::Repository::CapsuleSync, id: b1a5cec7-d7de-46c5-b6c9-2c3c35870760, execution_plan_id: 69ac8304-9da7-45d8-baeb-28d6b7bdd0b0} state changed: running
2022-03-25T11:30:02 [I|bac|46636ba5] Task {label: Actions::Katello::Repository::CapsuleSync, id: b1a5cec7-d7de-46c5-b6c9-2c3c35870760, execution_plan_id: 69ac8304-9da7-45d8-baeb-28d6b7bdd0b0} state changed: stopped result: success
2022-03-25T11:30:02 [I|bac|46636ba5] Task {label: Actions::Katello::Repository::ImportUpload, id: bee5baec-bb91-43b2-b518-529a9c560970, execution_plan_id: d71627a0-4381-4019-850a-dad5250d970a} state changed: stopped result: success
2022-03-25T11:30:06 [I|app|] Rails cache backend: File
2022-03-25T11:30:08 [W|app|] Setting remote_execution_workers_pool_size has no definition, please define it before using
2022-03-25T11:30:08 [W|app|] Creating scope :completer_scope. Overwriting existing method Location.completer_scope.
2022-03-25T11:30:08 [W|app|] Creating scope :completer_scope. Overwriting existing method Organization.completer_scope.
2022-03-25T11:30:08 [W|app|] Setting host_tasks_workers_pool_size has no definition, please define it before using
2022-03-25T11:30:09 [W|app|] Creating scope :exportable. Overwriting existing method Katello::Repository.exportable.
2022-03-25T11:30:10 [W|app|] Scoped order is ignored, it's forced to be batch order.
2022-03-25T11:30:26 [I|app|46636ba5] Rendering /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/views/katello/api/v2/common/async.json.rabl within katello/api/v2/layouts/resource
2022-03-25T11:30:26 [I|app|46636ba5] Rendered /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/views/katello/api/v2/common/async.json.rabl within katello/api/v2/layouts/resource (Duration: 8.1ms | Allocations: 5497)
2022-03-25T11:30:26 [I|app|46636ba5] Completed 202 Accepted in 27452ms (Views: 10.1ms | ActiveRecord: 36.6ms | Allocations: 173854)
2022-03-25T11:30:26 [I|app|d1300146] Started DELETE "/katello/api/repositories/236/content_uploads/81e72f00-3370-48c9-b3d1-1d391c1130be" for 1.2.3.4 at 2022-03-25 11:30:26 -0400
2022-03-25T11:30:26 [I|app|d1300146] Processing by Katello::Api::V2::ContentUploadsController#destroy as JSON
2022-03-25T11:30:26 [I|app|d1300146] Parameters: {"api_version"=>"v2", "repository_id"=>"236", "id"=>"81e72f00-3370-48c9-b3d1-1d391c1130be", "content_upload"=>{}}
2022-03-25T11:30:26 [I|app|d1300146] Authorized user testuser(Test User)
