Hanging while testing the connection between docker host and foreman
when I check test connection while adding docker host as compute resource to foreman. ist hangs as below. it doesn’t show connection successful or not
I added below option to /etc/sysconfig/docker and restarted docker daemon in docker host
OPTIONS=‘–selinux-enabled -H tcp://201.201.9.100:9999 -H unix:///var/run/docker.sock’
foreman version : 1.19.0
foreman_proxy version : 1.19.0
Please help me
Thanks
Laxman
Can you check ‘journalctl -f’ when you click on ‘Test Connection’ button on docker host ? and yes /var/log/foreman/production.log , these could be good starting points to know why its silent ?
