Heads up - Smart proxy and Sinatra 1.4.2+
Guys,
just a heads up - I have recently found that Foreman Proxy (HEAD) does
not work with the latest and greatest Sinatra 1.4.2 release. It ignores
Accept: JSON and only does return HTML which breaks Foreman of course.
The fix is pending, just to prevent you from W-T-H-I-G-O-H-? :wink:
TL;DR Don't want problems? Do not run bundle update sinatra…
Moving on. I did found out that rake test does not work when using
rbenv, because of broken library require statement in rubyipmi. Fix is
also pending:
I guess the workaround would be to ignore or turn off IPMI tests.
Take care!
Later,
Lukas “lzap” Zapletal
#katello #systemengine
You also hit an issue with OpenStruct for settings, did you solve that?
My concern was that the fix might have fixed it too well, so that
method_missing was correctly called on Settings and then the spec_helper
wouldn't be able to force certain settings "on" for the purposes of the
unit tests.
It should be possible to copy the settings.yml.example to settings.yml
and it just work. I think it only does by accident at the moment, as
the method_missing in Settings doesn't get run. Maybe there are
different implementations of OpenStruct or something?
··· On 02/04/13 09:28, Lukas Zapletal wrote: > Guys, > > just a heads up - I have recently found that Foreman Proxy (HEAD) does > not work with the latest and greatest Sinatra 1.4.2 release. It ignores > Accept: JSON and only does return HTML which breaks Foreman of course. > > The fix is pending, just to prevent you from W-T-H-I-G-O-H-? ;-)
Dominic Cleal
Red Hat Engineering
This OpenStruct issue was due to misconfiguration. I had to delete my
gem environment twice for some reason, something was still there (maybe
an environment variable) and I was using bad version of something.
It works now smooth.
··· On Tue, Apr 02, 2013 at 09:44:31AM +0100, Dominic Cleal wrote: > On 02/04/13 09:28, Lukas Zapletal wrote: > > Guys, > > > > just a heads up - I have recently found that Foreman Proxy (HEAD) does > > not work with the latest and greatest Sinatra 1.4.2 release. It ignores > > Accept: JSON and only does return HTML which breaks Foreman of course. > > > > The fix is pending, just to prevent you from W-T-H-I-G-O-H-? ;-) > > You also hit an issue with OpenStruct for settings, did you solve that? > > My concern was that the fix might have fixed it too well, so that > method_missing was correctly called on Settings and then the spec_helper > wouldn't be able to force certain settings "on" for the purposes of the > unit tests. > > It should be possible to copy the settings.yml.example to settings.yml > and it just work. I think it only does by accident at the moment, as > the method_missing in Settings doesn't get run. Maybe there are > different implementations of OpenStruct or something?
Later,
I'm running 1.4.2 with no apparent issues…
Greg
··· On 2 April 2013 09:28, Lukas Zapletal wrote:
Guys,
I can confirm the same behavior now on Fedora 18 and RHEL 6 (both with
Ruby 1.9.3 with rbenv - clean setup).
Can somebody help me reproducing it and confirm that my
patch does solve the issue?
··· -- Later,
We had a user (Karim) confirm the issue on 1.4.2 the other day, but he
downgraded to avoid it (successfully) rather than applying the patch.
··· On 05/04/13 14:16, Lukas Zapletal wrote: >>> just a heads up - I have recently found that Foreman Proxy (HEAD) does >>> not work with the latest and greatest Sinatra 1.4.2 release. It ignores >>> Accept: JSON and only does return HTML which breaks Foreman of course. >> >> I'm running 1.4.2 with no apparent issues.... > > I can confirm the same behavior now on Fedora 18 and RHEL 6 (both with > Ruby 1.9.3 with rbenv - clean setup). > > Can somebody help me reproducing it and confirm that my > patch does solve the issue?
Dominic Cleal
Red Hat Engineering
