I wasn't sure if I should add my issue to the other thread or create a new
one so this one is called #2 to make it easier to find in a search. (I hope)
On a fresh VM install of Ubuntu 14.04 and a fresh install of foreman 1.8
(dev environment), when I run the commands from 'How to create a foreman
plugin' I get this error after the 'bundle install' and subsequent
'service apache2 restart'.
some permissions were not found (ArgumentError)
/usr/share/foreman/app/models/role.rb:131:in add_permissions' /usr/share/foreman/app/models/role.rb:146:in
add_permissions!'
/usr/share/foreman/app/services/foreman/plugin.rb:198:in `block in role'
/usr/share/foreman/vendor/ruby/1.9.1/gems/activerecord-3.2.21/lib/active_record/connection_adapters/abstract/database_statements.rb:192:in
`transaction'
/usr/share/foreman/vendor/ruby/1.9.1/gems/activerecord-3.2.21/lib/active_record/transactions.rb:208:in
transaction' /usr/share/foreman/app/services/foreman/plugin.rb:196:in
role'
/home/emanners/git/my_plugin/lib/my_plugin/engine.rb:27:in block (2 levels) in <class:Engine>' /usr/share/foreman/app/services/foreman/plugin.rb:62:in
instance_eval'
/usr/share/foreman/app/services/foreman/plugin.rb:62:in register' /home/emanners/git/my_plugin/lib/my_plugin/engine.rb:18:in
block in
<class:Engine>'
/usr/share/foreman/vendor/ruby/1.9.1/gems/railties-3.2.21/lib/rails/initializable.rb:30:in
`instance_exec'
`run'
/usr/share/foreman/vendor/ruby/1.9.1/gems/railties-3.2.21/lib/rails/initializable.rb:55:in
`block in run_initializers'
/usr/share/foreman/vendor/ruby/1.9.1/gems/railties-3.2.21/lib/rails/initializable.rb:54:in
`each'
`run_initializers'
/usr/share/foreman/vendor/ruby/1.9.1/gems/railties-3.2.21/lib/rails/application.rb:136:in
`initialize!'
/usr/share/foreman/vendor/ruby/1.9.1/gems/railties-3.2.21/lib/rails/railtie/configurable.rb:30:in
method_missing' /usr/share/foreman/config/environment.rb:12:in
<top (required)>'
config.ru:3:in require' config.ru:3:in
block in <main>'
/usr/share/foreman/vendor/ruby/1.9.1/gems/rack-1.4.5/lib/rack/builder.rb:51:in
`instance_eval'
initialize' config.ru:1:in
new'
config.ru:1:in <main>' /usr/share/passenger/helper-scripts/rack-preloader.rb:112:in
eval'
/usr/share/passenger/helper-scripts/rack-preloader.rb:112:in preload_app' /usr/share/passenger/helper-scripts/rack-preloader.rb:158:in
<module:App>'
/usr/share/passenger/helper-scripts/rack-preloader.rb:29:in
<module:PhusionPassenger>' /usr/share/passenger/helper-scripts/rack-preloader.rb:28:in
<main>'
